99 Civic Ex Turbo - idle goes up and down
I installed a greddy turbo kit for a 92-95 civic on my 99 ex and i was just wondering if i should run the p2p ecu with the e-manage or should it be the obd1? Cause whenever i start it, idle goes up and down.. That's with the obd1 to e-manage.. I also checked for boost leaks but there was none.. E-manage is set on 5psi on stock internals.. I'm still on my stock injectors btw if that matters.. Much help would be appreciated. Thanks in advance!
You may have better luck here in the forced induction section:
https://honda-tech.com/forums/forced-induction-16/
Creating a thread title that summarizes your specific tech problem helps you get more responses by letting members know what specific information is needed -- Title edited.
the emanage is tuned for the kit and tuned for the OE fuel system. changing the ecu and tuning isnt going to do much for the 500 needed to change it out.
add a new fuel pump and injectors chip and tune and hes looking at 700-800 bucks
