95 Civic D15B Vtec-Not Starting
Hello. i just got my head resurfaced, valves and seals replaced and i put everything back on today. Went to start it but wouldn't turn over. i have spark on my spark plugs but not starting. could a bad cap and rotor cause a car not to start? i checked all my wires and sensors and everything is hooked up. i also check for fuel and its getting fuel fine. bad dizzy? main relay? bad timing? what would cause it too crank and not start? Thank you in advance! :mad: :thud:
Re: 95 Civic D15B Vtec-Not Starting
Are your wires in the correct order?
https://img3.imageshack.us/img3/9877...torfiringo.jpg If so did you recheck mechanical timing? |
check timing. make sure its on its marks. check your injectors with a noid light make sure your getting injector pulse.
Ok I will check these later on. Thanks you.
spark plug wires are correct. Injectors are getting pulse. It sounds like it wants to start and kind of back fires with a little bit of smoke coming out my throttle and intake but doesnt start up at all.
Check your cam timing
You still havvin issues. Try spray starter fluid. If start check fuel regulator. Make sure u have proper vacume to the regulator from intake manni
Ok got everything back on. I had my car cranking when trying to start but never turned over. I checked all my wiring and looks like its all connected right. I tried again this morning and now when I push the clutch in and now car won't crank at all. My kill switch is disabled but not cranking at all now when I try to start. i can jump it by the starter in the engine compartment but not from the key. It worked yesterday but this morning nothing. Almost like the clutch wiring broke or something. Need help. Also I have no power coming out of my ignition coil in my distributor but that's a different story. Please help. Thank you
From your other thread:
Originally Posted by 24TEN
(Post 49259516)
Originally Posted by playa24vtec
(Post 49259244)
No. More like cranking but not turning over.
(Post 49259244)
Someone told me to check my ignition coil in my dizzy. How do you test that to see if there power coming from there?
(Post 49258405)
You should have the mods lock the other thread since you are now asking the same question in two different threads, this one having the more relevant thread title. |
yeah i know this thread was a better description. sorry for the confussion.
No worries, let's just get this thing solved. I know it sucks putting in so much work and then not being able to have it run properly. I'm sure we've all been there at one point or another (or repeatedly).
bump!
need help please! |
No crank problem - check the rubber stopper that presses on the starter switch at the top of the clutch pedal. It may have fallen out.
You may have posted this answer already and, if so, I am sorry for asking again. Did you check the timing?
yeah ill check the rubber stopper today. I checked timing and seems to be good. i dont think my coil is getting any spark though. might need a new dizzy.
You can't check for spark unless the starter cranks the engine.
Originally Posted by RonJ@HT
(Post 49271614)
(Post 49272143)
yeah i can manually do it from the starter in the engine. jump it.
First fix the crank issue and then check for spark. |
You mentioned head resurfacing... was any other work done such as re-cutting valve seats and/or lapping valves ??? If so, your valve adjustment may be too tight and thus not creating enough compression to allow the engine to run. The starting issue sounds like RonJ has mentioned above... check the clutch switch pad. Dark blue plastic disc parts along with a small cone found in the floor mat is a dead giveaway, and a common failure for vehicles your age.
if your getting spark to all of the plugs what makes you think its the distributer?
