93' Del Sol ignition problems & misfiring D16z6
Old Feb 4, 2011 | 10:46 AM
NarCiuss's Avatar
Default 93' Del Sol ignition problems & misfiring D16z6
I got a 93' Del Sol D16z6 with 180k.
I changed the spark plugs, ignition module, coil pack, cap and rotor, fuel filter and oil.
I started her up and she was idling normal but when I go to drive my tac is all over the place. While going 10mph it's jumping fom 4k-5k and it misfires like crazy.
Should I try different plugs? She was running fine before I changed everything.
Old Feb 4, 2011 | 11:10 AM
Former User's Avatar
Default Re: 93' Del Sol ignition problems & misfiring D16z6
Are the plug wires installed in the correct firing order? If so, have the "new" igniter unit tested and check that its wires are tight and installed correctly.
Old Feb 4, 2011 | 01:18 PM
NarCiuss's Avatar
I do believe the firing order is correct but if a diagram is around that would be great. If the order was wrong it wouldn't start would it?
When I did change the plugs Cylinder #3 was fouled pretty bad.
Would the plugs cause my tac to jump all over the place?
J's91Teg
Jan 13, 2010 04:43 PM
ChrisDaun
Dec 5, 2007 12:43 PM
jimmer84
Nov 6, 2004 05:41 PM
