93 Civic Cx - Can I run a Type R rear sway bar and front subframe brace
I have a 93 Cx. I am trying to figure out if I can run a type r rear sway bar. I have aftermarket LCA's so the mounting points are on the control arms. Do all civics have the mounting points on the rear subframe? Not home to look cause I am deployed.
Next question. Can I use the front subframe brace from the type r as well. Does the cx front subframe have the four bolt holes to mount it? Again cant look at cause I am deployed. Any imput on wont work and will work will be appreciated. |
Re: Suspension question
Originally Posted by Hondatypr636
(Post 48342110)
(Post 48342110)
Any input on wont work and will work will be appreciated. |
^ for all this and thanks for serving!
You also dont need aftermarket LCA's.. EX LCA's will work fine. |
Thanks for the info guys. Just making sure before I send my wife to acura to order some parts.
You'll want to get an ASR. At minimum, a Beaks kit. NOT THE BAR. if you can still get them.
I would recommend going with the ASR though. What control arms are they? Some aftermarket controls arms on the EG/DC have the endlink holes in the wrong spot which would then require adjustable endlinks. |
Originally Posted by 98civdx
(Post 48344984)
I would recommend going with the ASR though. What control arms are they? Some aftermarket controls arms on the EG/DC have the endlink holes in the wrong spot which would then require adjustable endlinks. But If you want an authentic ITR you can get them much cheaper in the classifieds than paying dealer prices at Acura. |
Re: 93 Civic Cx - Can I run a Type R rear sway bar and front subframe brace
BNIB is only about $100
I've seen people ask $150+ for a used ITR bar. |
I can get it brand new from acura for $100
I found the beaks subframe reinforcement kit on jhp for $70. I am gonna be using blox lower control arms with the sway bar.
(Post 48345406)
I've seen people ask $150+ for a used ITR bar. It's not rare. |
let us know how the sway bar feel when you up it on. I'm looking to do the same thing
Just installing a Type R rear sway bar isn't going to give you magical results, but the sway bar with a few other wise suspension choices will make a huge difference.
Originally Posted by weavertime1
(Post 48346266)
(Post 48346099)
Originally Posted by dirty19
(Post 48346106)
For real?? what do these people think its made of gold?
It's not rare. :ugh: I just hit the back button. |
Minty with low miles? Its a piece of steel... LOL what a meathead.
It takes all kinds these days. |
Exactly what I said.
Sadly more dummys then smart people. |
(Post 48346715)
(Post 48346917)
Not to clog the thread, but have you seen the movie Idiocracy?
:P |
Never even heard of it.
Watch it to see where our world is going.
