2000 Civic,Cranking but not starting..HELP 😭
My car has been down for now a month and I'm just stuck in what to do next...Please help out...
It's a 2000 Civic Sedan,swapped with a B20B.Been driving it for 2 years,it's the dd.I parked it up from coming home one Evening.Everything is Fine.I got a rental and went on a 2 day vacation with my family.So when I came home to start it,it just cranked and did not want to start roll over whatever..Did some testing checked the fuse boxes for anything blown..Tested for spark,and I'm not getting spark.So I had a spare dizzy laying in the closet so I swapped it in and Nothing.Just cranks no start..I put in New NGK wires and plugs.A New Cap and rotor in the Dizzy.Main relay clicks,fuel pumps turn on...And now I'm stuck here,don't know where else to look..It has a stepdown Obd1 p75, swapped a Obd1 P28 and still not starting..Guys help me out.. Thank you. |
Re: 2000 Civic,Cranking but not starting..HELP 😭
Still need help ppl.
Thank you |
try testing coil and icm:
https://www.team-integra.net/forum/b...eshooting.html bad coil is #1 no spark culprit, will fail sooner than icm. i always carry a spare. |
Is the dizzy spinning?
Originally Posted by tony_2018
(Post 51942931)
Originally Posted by tamboo
(Post 51942905)
(Post 51942905)
https://www.team-integra.net/forum/b...eshooting.html bad coil is #1 no spark culprit, will fail sooner than icm. i always carry a spare. I'm at a road block here ...lol |
Also check whether fuse 9 is blown.
Originally Posted by muellersfan
(Post 51946309)
Going to take a look now.. |
(Post 51946309)
Originally Posted by Chrisfrom1986
(Post 51946943)
Thanks, saved me from unnecessarily taking apart my distributor.
can you hear the fuel pump prime when you turn the key to on but with out cranking? check the main fuel pump relay inside the glove box.
Originally Posted by my fear
(Post 51947007)
Solved.
Purchase a brand new dizzy,fuck it. My car starts and drives.HOORAY |
