2 keys = boo
bought car used. 99 si.
1 key = for everything except ignition 2nd key = ignition (due to theft: previous owner) any way i can make it all one key or get an ignition thats takes that key or is that too much trouble/money?! http://images.honda-tech.com/set1//smile/emcrook.gif |
Re: 2 keys = boo (blackrag)
Have you tried the dealer?
Re: 2 keys = boo (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Have you tried the dealer? </TD></TR></TABLE>
negative. not yet. i was just seeing if anyone has run into this problem before. |
Honda dealers will retumble your ignition to another key for a small fee.
Get keyless entry installed. Problem solved. Otherwise, look at it as an extra security measure.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Honda dealers will retumble your ignition to another key for a small fee.</TD></TR></TABLE>
what's that mean? http://images.honda-tech.com/set1//smile/emcrook.gif |
Re: 2 keys = boo (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Get keyless entry installed. Problem solved. Otherwise, look at it as an extra security measure.</TD></TR></TABLE>
i have keyless entry, but if i leave the other key (door key) at home, i wont be able to get into my trunk and/or take back seats down, and/or open the car if something happened to the keyless entry. naw'saying? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrag »</TD></TR><TR><TD CLASS="quote">i have keyless entry, but if i leave the other key (door key) at home, i wont be able to get into my trunk and/or take back seats down, and/or open the car if something happened to the keyless entry. naw'saying?</TD></TR></TABLE>
Is it a real pain in your ass to have another key on your key-ring "just in case"? If it is, you can hide it on the car somewhere so you can get to it if you need it. |
Re: (blackrag)
what's that mean? http://images.honda-tech.com/set1//smile/emcrook.gif </TD></TR></TABLE> It means they'll make your ignition cylinder work with a different key. |
Re: (Eran)
i thought it was normal to have to different keys? My 96 Civic EX has a key that does all the doors and one for the ignition. I thought I heard it called a Valet Key.
Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 »</TD></TR><TR><TD CLASS="quote">i thought it was normal to have to different keys? My 96 Civic EX has a key that does all the doors and one for the ignition. I thought I heard it called a Valet Key.</TD></TR></TABLE>
No, a valet key only works for the driver's door and the ignition. It's not normal at all not have a key that doesn't work everything. |
Re: (Eran)
It means they'll make your ignition cylinder work with a different key.</TD></TR></TABLE> do you have an estimate on how much that'd cost? thanks for the help. |
