02 Civic EX rear drum brake service..
hey guys, i've changed several brake pads before on disc brakes, but i've never touched rear drum brakes before.. my friend asked if i can work on her 02 ex..
anyone know of a diy i can check out? also how would i tell if the shoe needs replacing? thanks.. |
Re: 02 Civic EX rear drum brake service.. (syclone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syclone »</TD></TR><TR><TD CLASS="quote">hey guys, i've changed several brake pads before on disc brakes, but i've never touched rear drum brakes before.. my friend asked if i can work on her 02 ex..
anyone know of a diy i can check out? also how would i tell if the shoe needs replacing? thanks..</TD></TR></TABLE> How many miles does she have? I'd doubt that they need changing yet, I've never had to do a drum before 100K, and I've had a few cars that I've never touched them on. |
Re: 02 Civic EX rear drum brake service.. (EX_AutoXer)
don't know..
hopefully it's as you said where it won't need replacing.. so then i guess i'd like to know how to at least inspect them.. Modified by syclone at 11:18 PM 2/14/2005 |
How detailed of a project would it be to change the rear drums to discs?
Re: 02 Civic EX rear drum brake service.. (EXCoupe03)
about average.. it wasn't that difficult.. i swapped my 97 hatch rear drums to disc..
but the 02 ex isn't mine, nor is it to be used for performance by the owner so it's just a maintenance item.. |
transform to rear disc's! she be happier! https://honda-tech.com/forums/images/smilies/emthup.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syclone »</TD></TR><TR><TD CLASS="quote">but the 02 ex isn't mine, nor is it to be used for performance by the owner so it's just a maintenance item..</TD></TR></TABLE>
Just use it while coasting to see if it slows the car down. If it does, they're probably fine. The cable may need adjusting though, becuase they stretch. If they were worn, you'd hear squealing, it's the 'wear indicator' for the drums. |
