00 Civic Si B18C HELP TURBO PLEASE!!!!
Hey guys I have a 00 Civic Si B18C swap, aftmkt fuel pump edelbrok victor x intake manifold, stage 3 clutch, thats about it for the motor its all stock inside and I have exatly 1,500$ to start, and I want to turbo this thing, Can I do it with 1,500$??? and...Can I do it w/o messing with the motor/ecu/injectors/tune? on 7psi?
please help |
Re: 00 Civic Si B18C HELP TURBO PLEASE!!!! (positiveforce63)
You sure don't know much about turboing your car..
To turbo your car, at the very least you need the following: Turbocharger: Pick which size and trim turbo is gonna work best for your application and goals --> Exhaust Manifold: Either log/cast/equal length. Make sure it was made for your turbo (t3, 4bolt, 5bolt, dsm, etc.) --> Downpipe: Again must be custom for your turbo/manifold choice. A flex pipe and o2 bung are nice to have while creating a downpipe --> Wastegate: Choose a wastegate size (also what psi spring you'd like to run) according to application such as amount of air flow and psi from turbo --> Intercooler: Choose either a FMIC (Front Mount InterCooler) or Side Mount Intercooler. Fmic is more bling bling :D as well as better cooling --> Blow off valve: This is acutally an opional (but very recommended part). Doesnt really matter which one you choose. Pick a sound you like --> Fuel Manegment: One of the most important parts on your turbocharged car. I would highly suggest running a programable chiped ecu or standalone device, but running a AFC hack controller can be used as well --> Fuel Pump : You will probably need an upgraded fuel pump to support the added fuel consumption. Can be either internal or external --> Injectors : To support added air induction, more fuel is need... hence bigger injectors. Buy size according to application --> Map Sensor: Stock maps can only read up to ~10.63 psi, if you plan to go higher upgrade to a 2bar or 3bar map sensor --> Intercooler Piping: You can buy a ic piping kit, but usally will always take some modification to fit your exact application --> Couplers/t-bolts: You will need silicone couplers to bind the two ic pipes together as well as t-bolts (or screw clamps which i dont recommend) to tighten those couplers down --> Oil drain/feed lines: Every turbo needs oil, so you must buy an oil feed and drain line kit. ss lines are recommend |
is there a site to get turbo info and what not? i always hear people talking about t-series turbos, like t3/t4, t3, t28 etc.
ive never looked into forced induction but have an idea how it works, i just dont know anything about sizes, trims, what size injectors to run, and the more complicated things like ecu modding. |
Re: (fatpride111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatpride111 »</TD></TR><TR><TD CLASS="quote">is there a site to get turbo info and what not? i always hear people talking about t-series turbos, like t3/t4, t3, t28 etc.
ive never looked into forced induction but have an idea how it works, i just dont know anything about sizes, trims, what size injectors to run, and the more complicated things like ecu modding.</TD></TR></TABLE> garrett turbos is a good site |
I have a full turbo kit ready to go for that car, all brand new in the box including the downpipe, BOV, intercooler, boost controller, wastegate and of course the turbo. $1500
Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by positiveforce63 »</TD></TR><TR><TD CLASS="quote">Can I do it with 1,500$???</TD></TR></TABLE>
Absolutely not. I wouldn't even consider it on a daily driver. On a side note, take this to FI. |
hey this is for NOKTURNALCARCLUB e-mail me at untouchable6319@yahoo.com, with that nokturnalcarblub as subject or something, so I know who it is when i get the e-mail, but i looked at the cardomain, and I like that set up alot and i'll buy it !!! but I don't want to run 28psi, lol do u have a stock spring for the waste gate so i can run 7-8, mind u , my motor is going to be all stock for about a year, not a EVERY day driver, but 4 outta 7 days a week most likely, get back to me..thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by positiveforce63 »</TD></TR><TR><TD CLASS="quote">hey this is for NOKTURNALCARCLUB e-mail me at untouchable6319@yahoo.com, with that nokturnalcarblub as subject or something, so I know who it is when i get the e-mail, but i looked at the cardomain, and I like that set up alot and i'll buy it !!! but I don't want to run 28psi, lol do u have a stock spring for the waste gate so i can run 7-8, mind u , my motor is going to be all stock for about a year, not a EVERY day driver, but 4 outta 7 days a week most likely, get back to me..thanks </TD></TR></TABLE>
lol, this is priceless. buying a turbo kit you know nothing about because you saw it on cardomain. rice https://honda-tech.com/forums/images...s/emthdown.gif |
Re: 00 Civic Si B18C HELP TURBO PLEASE!!!! (confucioussae)
im looking to buy a turbo kit for around 1,500$ , good condition, its sold i don't care what kind of set up it is, im just looking for a daily driver, and I wanna turbo my civic, so...im not looking to make a 10 second car. I just want it to be faster than a 15.6, what i am running, thats all i care about and reliability
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by positiveforce63 »</TD></TR><TR><TD CLASS="quote">my motor is going to be all stock for about a year, not a EVERY day driver, but 4 outta 7 days a week most likely, get back to me..thanks </TD></TR></TABLE>
Your motor isn't going to last a year. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by positiveforce63 »</TD></TR><TR><TD CLASS="quote">thats all i care about and reliability</TD></TR></TABLE> You have no idea what you're in for. Please document the progress of your turbo project. Please. Why don't you do something a little lower maintenance like an H or F2B. Way better platform and a little more "user friendly." You could do an H swap and have 200hp stock or boost your bone stock B and make 225-250hp. If you're properly tuned. Which I'm not so sure will happen. Save $800 more dollars, buy an F20 long block and an F/H2B kit. Modified by Tony Starks at 2:05 AM 9/10/2007 |
If your serious then check out http://www.homemadeturbo.com
hey bro, the turbo kit im selling is not the one that is on the car. I have 2 turbo cars now, a track car and a daily driver, but im selling the 3rd turbo kit that ive had laying around for about 6 months now and its all brand new in the box, i can take pics of the parts and sent them to you just pm me your email address
LOL, this kid's going to turbo this car and get that shit stolen the next week. Represent Bronx NYC! https://honda-tech.com/forums/images...s/emsmilep.gif
Re: 00 Civic Si B18C HELP TURBO PLEASE!!!! (Extradition)
pics to untouchable6319@yahoo.com thanks
