00 civic
I need help i have a problem with my civic its an automatic and the tranny bad. the D is flashing and the altrnator wont charge. the way this started was when my o2 sensor scrapped on the ground because the car was too low and i already changed the tranny once before and it worked fine and then it happened again. I think its something electrical cuz the tranny was shifting good until the O2 scrapped on the ground. please i need help
Re: 00 civic
Take it to a mechanic shop.
Re: 00 civic
well im trying to see if i can fix it myself
Re: 00 civic
So I don't get it. You know the transmission is bad. Swap it out.
Re: 00 civic
NO I DNT THINK THE TRANNY BAD I THINK ITS SOMETHING ELECTRICAL
Re: 00 civic
You may have bad/ shorted wiring. Check the bottom of the vehicle or any connector going to the trans to see if the wiring is frayed or damaged.
Re: 00 civic
I'm really trying hard to decipher your post.
You said this happened before, which is why you swapped the tranny originally, but now that it's doing it again because of the 02. Was the 02 damaged, and was it replaced? How was the 02 even damaged by the car being to low? How do you know the alternator isn't working? Do you have a battery light? If you think there is an electrical problem and the alternator is bad, why don't you replace that and see if that is the problem? What specifically is the tranny doing? |
Re: 00 civic
Should of did a 5 speed conversion instead.
Re: 00 civic
Originally Posted by ek9-85
(Post 44438408)
Re: 00 civic
ok the problem started when the O2 sensor scrapped on the ground and wires were ripped off then the D on the cluster started to flash then my rpms stopped working and my speedometer and then the alternator stopped working cuz i think it made a short when the O2 sensor scrapped. the first time it did this i thought it was just the tranny so changed it and the problem went away. but now since it happened again im thinking it got to be something with the wiring cuz the tranny was running good i just dnt wnt to buy another tranny
Re: 00 civic
when i put the tranny in drive it goes in hard it makes a clunk noise and when i drive it ,it dont want to go its rough
Re: 00 civic
So is the tranny bad or not? Sounds like you're just guessing instead of troubleshooting. And how do you destroy an O2 sensor from being too low?
Re: 00 civic
because i made the mistake of by buying a exhaust on ebay the hole for the O2 sensor is facing down
Re: 00 civic
(Post 44438408)
Re: 00 civic
You bought a highflow cat or test pipe didn't you.
Re: 00 civic
yeah some cheap shit trying to go the cheapest way (not doing that again)
Re: 00 civic
o2 sensors are usually ran through ur alternator circuit and will blow a fuse. so check the fuses for ur alternator and others. if the D is flashing on ur automatic. once u reset the ecu again and if it returns then ur transmission is due for service and could possibly be burnt up. i dont know if u have been experiencing any lagging or shifting issues lately?
Re: 00 civic
no that tranny was running beautiful and when i bought it it on had 90k and ran better than the first one i changed its weird how both times i scrapped the O2 sensor and this happened
Re: 00 civic
So this has happened 2 times exactly the same way and you don't have a clue why? YOUR CAR IS TOO LOW!!!
Re: 00 civic
(Post 44439028)
Originally Posted by Targa250R
(Post 44438974)
You blew the alternator fuse, which completes the circuit leading to the alternator, both oxygen sensors, and the VSS.
Re: 00 civic
yeah i learned thats why i put original suspension and it still happened cuz the O2 sensor facing down
Re: 00 civic
(Post 44439045)
Uh, no, it's not "weird" . . .
Re: 00 civic
It's not weird.
Re: 00 civic
(Post 44439059)
wht u mean not weird???
Re: 00 civic
so any ideas im going crazy with these problem
