Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
calibrate the new clock spring
Old May 6, 2025 | 10:35 AM
gjgogol's Avatar
Default calibrate the new clock spring
Hello - Someone stole my steering wheel air bag out of my 2017 Civic EX 2.0. Since wires were cut, It appears I need a new air bag assembly and clock spring. Does anyone know if I will need to "calibrate" the new clock spring and if so can it be done without a scanner?
Old May 12, 2025 | 03:53 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: calibrate the new clock spring
The cable reel (clock spring) requires manual alignment of the arrow mark.
There isn't any calibration.
If the following were done, then the VSA Sensor Neutral Position Memorization should be performed with Honda HDS.
- Update or replace the VSA modulator-control unit.
- Update or replace the SRS unit.
- Remove the steering wheel.
- Disconnect the steering joint.
- Wheel alignment adjustment.
1junkycivic
Apr 13, 2009 02:17 PM
Jhonny Ricer
Suspension & Brakes
Mar 29, 2007 03:30 AM
HondaCutter
12
Jan 28, 2004 09:21 AM
Jesse H
Mar 10, 2002 07:34 PM
