Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how to replace wipers on a sedan
Old Jun 7, 2008 | 08:02 PM
civic710's Avatar
Default how to replace wipers on a sedan
hey guys. just wondering if any of you know how to change the wipers on the sedan? i know there's a write-up on the FAQ but it seem like it's only for the coupe. Honda had to go make some different wipers for the sedans i guess. did a search too didn't find anything useful. be great if someone could give me a little help.
Old Jun 8, 2008 | 09:16 PM
civic710's Avatar
no one?
Old Jun 8, 2008 | 09:36 PM
lando griffin's Avatar
Default Re: (civic710)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedamaja &raquo;</TD></TR><TR><TD CLASS="quote">Everyone seems to be having some trouble with this so after I finally mine off i figured and tell everyone how it works.
Take a small flathead screw driver and stick it between the wiper arm and the little black cover that's over the hook. Place your fingers on the grips and apply minimal pressure. While doing this gently pry forward away from the arm and towards the center of the car. The Cover will move about a 1/4" you should now be able to lift the cover up and off.
See the plastic hook in the middle of the clip. that is what locks into the silver shoe seen on the wiper blade picture.
To remove the insert itself follow the honda instructions below. Just push down the rub on the blade and slide the insert out. You should be able to fit any refill that is 6mm wide although most this length are 8mm.
You may be able to replace the refill with out removing the blade.</TD></TR></TABLE>
Old Jun 9, 2008 | 03:57 AM
pato5449's Avatar
Default Re: how to replace wipers on a sedan (civic710)
https://honda-tech.com/zerothread?id=1926421
hometheaterman
Apr 26, 2008 07:29 PM
aarontrini85
Apr 23, 2007 05:14 PM
Hellzcivic
18
Apr 17, 2007 03:15 PM
crxgator
Sep 28, 2006 09:30 AM
Jesterian
Dec 19, 2005 01:02 PM
