Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Problem with Eibach Pro Steet S Coilover/Spring
Old Aug 28, 2008 | 08:44 PM
rjwalker's Avatar
Default Problem with Eibach Pro Steet S Coilover/Spring
As my first modification to my 2001 Sedan LX, I chose Eibach Pro Street S
coilover/springs. After everything was down and tightened, i took the car down my
driveway. At the bottom a loud occurred, instantly pulled over. Open the trunk
to find that both rear Top Hats broke clean off. The top ring where the bushing and
Shock is screwed down had shot off like a beer bottle top. Now tirerack.com didn't
specify that i should buy after market tophats, so is there maybe something i did to cause this?
Old Aug 28, 2008 | 09:03 PM
rjwalker's Avatar
Default Re: Problem with Eibach Pro Steet S Coilover/Spring (rjwalker)
bump
ten views no replys?
c'mon i'm ride-less until this gets fixed
Old Aug 28, 2008 | 10:26 PM
toyomatt84's Avatar
Sanji
Installation wise, does the kit require you to use the factory top hats? If so, you might want to check the FAQ's for the spring installation link.
Old Aug 29, 2008 | 07:22 AM
rjwalker's Avatar
The specs are in german, and its a single sheet of paper. Been looking for an english pdf... nothing yet.
baaao
Nov 11, 2008 08:11 PM
mportracer33
Suspension & Brakes
Feb 13, 2008 10:43 AM
mikeunreal
Suspension & Brakes
46
Nov 8, 2005 07:02 PM
4thgenlude
15
Oct 24, 2004 08:44 PM
vaporDA6
Mar 11, 2004 11:07 AM
