Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Possible VTEC problem ??
Old Jun 8, 2008 | 12:16 PM
Psychochik's Avatar
Default Possible VTEC problem ??
Hey guys, I encountered a problem lastnite. First my check engine light came on and then about 5 minutes later as I was taking off from a red light, I got at about 4500rpm's or about when my VTEC engages and the car sputtered and shook wierdly.
As soon as I down shifted and was below 4500 it was fine.
Its making no strange noises and runs fine except when shifting and above 4500.
Any possible explanations ?? This is entirely new for me and any help would be greatly appreciated.
Thanks in advance !!
Old Jun 8, 2008 | 02:40 PM
BojeEM2's Avatar
Default Re: Possible VTEC problem ?? (Psychochik)
You are proably low on oil. Your car is in "Limp mode"---I think that is what it is called.It stops you from going over 4500rpm so you dont hurt the motor.When is the last time you had your car serviced??
Old Jun 8, 2008 | 05:12 PM
count me out's Avatar
* B A N N E D *
find out what the cel is.
Old Jun 8, 2008 | 07:39 PM
toyomatt84's Avatar
Sanji
Default FV-QR
Well, VTEC kicks in at 2700 RPM's, so I wouldn't directly tie it in to that. And count me out is correct in that you'll want to have the codes pulled. You can have it done for free at some local auto parts stores (ex. PepBoys, AutoZone, Advanced Auto Parts).
Old Jun 9, 2008 | 03:55 AM
Boilermaker1's Avatar
whether VTEC works or not, the rev-limiter for no VTEC kicks on somewhere around 4000 rpms. I know this for a fact, as I forgot to plug the pressure switch in once and it did it, and I've got VTEC manually set to 2200 (yay Kpro).
You've gotta scan the code to see whats wrong with it.
Old Jun 18, 2008 | 07:17 PM
imationdawg's Avatar
did u ever get this fixed if so wut was it?
01em2slvr
Nov 11, 2009 12:43 PM
Fastwhip
Aug 2, 2007 03:58 PM
aznguy0087
May 9, 2007 06:11 AM
xtreme-customz
18
Dec 1, 2005 07:51 PM
BI8C1vic
Mar 4, 2003 10:17 PM
