Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Leaking problem!!!
Old Jun 14, 2008 | 04:08 PM
Revolver123's Avatar
Default Leaking problem!!!
So today my car started leaking water on the passenger side floor. It's coming from below the glove box. I don't know what's leaking but I'm guessing it's the AC since it's water. It especially leaks on turns. I'm not talking dripping, I'm talking a good amount of water like a squirt gun coming out. It's leaking all over the floor and ruining the carpet. I'm afraid a molding smell might develop or even worse, rust.
Anyone know what could be causing this?
Old Jun 14, 2008 | 05:01 PM
skipbarber's Avatar
wow, you just solved your air conditioning problem! The water is coming off of the evaporator. You probably have a blocked drain hose. Since the water can't drain, it freezes onto the evaporator, thus the blower motor can't blow hot air through it. the hose comes out at the very bottom of the firewall on the drivers' side. check it for blockage. If you leave the car running with the a/c on, make sure you can see water drip out from it. When ice or water blocks the air flow in the evaporator, you're not going to get cool air in the cabin.
HondaAccordTdR
Aug 31, 2008 02:51 PM
plainburg
Jul 14, 2006 07:19 PM
pcorad
Jul 4, 2005 08:51 AM
matto2413
Feb 19, 2005 07:40 AM
OgunplayGSR
Jul 12, 2002 10:12 PM
