Code p0118.. HELP!!!
Car just recently started to run like **** last month havent driven it since.
P0118 - Engine Coolant Temperature (ECT) sensor circuit high input.
car feels like running low on power, rough idle, hard to start & temp gauge doesnt work.
anybody run into this problem?
... in a nutshell ...
P0118 - ECT Sensor Circuit High Voltage
1. Turn the ignition switch On. (II)
2. Check the ECT with a scanner.
Is - 4 °F (-20 °C) or less or 5 volts indicated?
Yes - Go to step 3.
No - It was an intermittent failure. Check for loose or poor connections at the ECT sensor and at the ECU.
3. Turn the ignition switch Off.
4. Disconnect the ECT 2-pin connector.
5. Connect terminals 1 (green/yellow wire) and 2 (red/white wire) with a jumper wire.
6. Turn the ignition switch back ON. (II)
7. Recheck the ECT with the scanner.
Yes - Go to step 8.
No - Replace the ECT sensor.
8. Turn the ignition switch Off.
9. Remove the jumper wire.
10. Turn the ignition switch back On. (II)
11. Measure the voltage between terminal 2 (red/white wire) of the ECT sensor connector and a ground.
Is there about 5 volts?
Yes - Go to step 12.
No - Go to step 16.
12. Turn the ignition switch Off.
13. Disconnect ECU connector A. (31-pin connector)
14. Connect terminal 1 (green/yellow wire) of the ECT sensor connector to a body ground using a jumper wire.
15. Check for continuity between terminal 10 (green/yellow wire) of ECU connector A and a body ground.
Is there continuity?
Yes - Update the ECU software if it doesn't have the latest. (rarely the case) Or swap your ECU with one that is known to be good and recheck. If the problem goes away when using the sub-ECU, keep it.
No - There's an open in the wire between the ECU (A10) and the sensor. You'll need to find and repair it.
16. Connect ECU connector terminals A10 (green/yellow wire) and B8 (red/white wire) with a jumper wire.
17. Turn the ignition switch On. (II)
18. Check the ECT with a scanner.
No - There's an open in the wire between the ECU (B8) and the ECT sensor. Find it and repair it.
Good luck with it.
Yes - Go to step 3.
Yes - Go to step 8.
No - Go to step 16.
Good luck with it.
How is your coolant level in the radiator? These cars are notorious for blown head gaskets.
why do people start treads like this you have a code for ect sensor.....replace the freakin sensor then if the problem continues it could possibly be something else but 9 out of 10 cars it will be the sensor
SickWitIt2.0
Jan 22, 2005 11:27 AM
pbadger
Nov 14, 2004 12:50 PM
CivicSiRacer
11
Aug 27, 2002 03:27 PM
