Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
5lug conversion question?
Old Sep 11, 2009 | 01:44 PM
DennMann89's Avatar
Default 5lug conversion question?
so i put the rsx 5 lug conversion on. control arms and all. and set the car back down on the tires and the wheels were almost touching the rear of the fender...
could this be bc the control arm(s) are bent or what?
ill will attach pics to explain.
left aint as bad as the rt
Old Sep 11, 2009 | 03:34 PM
homelessEm2's Avatar
Default Re: 5lug conversion question?
this is a stupid question but are you sure you either dont have the control arms reversed/flipped? there should be a little tab that comes off the rear of each control arm for an antisway bar. my bet is they are flipped on the wrong sides.
lemme know after you check.
Old Sep 11, 2009 | 04:52 PM
DennMann89's Avatar
nah good check but no the arms can only go one way into the sub frame...and i hav the sway bar and everything hooked up and ready to go...thats why i am stumped...
i was thinking maybe trying to use the em2 arms on the rsx hub...idk it that wld either work or mate up...you know? :/
Old Sep 11, 2009 | 06:59 PM
baron340's Avatar
You should be able to use the EM2 LCA on with the rsx knuckle. I don't see why you couldn't. That would probably be your best bet.
Old Sep 11, 2009 | 07:48 PM
i just switched my em2 arms to rsx ones that i had energy suspensions bushings pressed into. they can be installed upside down if you have the sides switched (driver on pass. side) and the sway bar would still bolt up so check and look carefully.
Old Sep 13, 2009 | 03:48 PM
DennMann89's Avatar
well my sway bar is connected so i dnt think thats the problem...but thanx for your input
Old Sep 13, 2009 | 04:05 PM
Harlowe's Avatar
Function>Fashion
It will still connect if the arms are upside down. Check again, and maybe post pictures of the control arms installed.
Old Sep 14, 2009 | 06:07 PM
aLlmoTorcoUpe's Avatar
hey all this is a bit off the question but for ep3 the modle of 04 has back disc conersion on them or not i for got about taking a good look at it. lmk.
Old Sep 14, 2009 | 06:32 PM
Johnny_5's Avatar
Is that English?
US-Based EP3's come with rear discs, regardless of year/model.
Old Sep 16, 2009 | 06:45 PM
DennMann89's Avatar
yeah ep3 does hav disc braks on rear but first off im talking about the front and second off the ep3 is 4 lug and not 5
Old Sep 16, 2009 | 07:22 PM
actually ep3 has 5lug from 04-05...i would know i have an ep3 5lug conversion
Old Sep 17, 2009 | 08:06 PM
DennMann89's Avatar
oh ok well good info. now i know
Old Sep 17, 2009 | 08:07 PM
DennMann89's Avatar
also, i did the rear today and my sway bar in the rear doesnt match up...do i hav to get an rsx rear sway bar?
Old Sep 17, 2009 | 09:12 PM
Harlowe's Avatar
Function>Fashion
Either swaybar will work, they are the same shape...
Did you put the swaybar on wrong? It's possible.
Old Sep 19, 2009 | 05:18 PM
DennMann89's Avatar
yes possible but i never took it off...im using the stock one rt now...so idk if i shld get the rsx one...
BWRSUPPORT
36
Oct 14, 2013 01:57 PM
K. Legaspi
12
May 22, 2013 07:45 AM
bart simpson
Jan 7, 2011 09:27 PM
3vilMonkey!
10
Nov 1, 2004 04:06 PM
