Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic SI - Knocking sensor replacement
Old Mar 30, 2025 | 07:03 PM
Philip54's Avatar
Default 2002 Civic SI - Knocking sensor replacement
I got a P0325 code, and I need to replace the knocking sensor. I understand that the sensor is located at the front of the engine. Replacing the sensor from the top will likely require removing the induction manifold. Replacing the sensor from the bottom will not require the removal of many parts; however, it appears that work will need to be performed 'blindly', as I cannot see the sensor from the bottom of the car. Any recommendations on how to proceed?
Thanks
951parts
Aug 9, 2012 11:43 AM
mar7pau
Aug 29, 2010 10:34 AM
prostreetonline
Jul 10, 2004 12:21 PM
