.: post your 96 spec Type R rims :.
Im surprised you know how to swap to 4x114 but you dont know about using the correct lugs.
You are supposed to use the ones on the left, hence the sitting point. Sure those Rays may look cute on your OEM wheels, but they are incorrect. Your lug nuts could come loose since they arent seated properly.
Originally Posted by Wheel & Tire FAQ
The "seating area" (or "seat") is the area of the lug nut, and the area of the wheel, that come in contact with each other. Stock Honda/Acura wheels have a ball/radius/spherical shaped seating area, and need lug nuts (such as stock lug nuts) which also have the same shaped seat. Aftermarket wheels use a tapered/conical/cone shaped seating area and need lug nuts (including most tuner lug nuts) which also have the same shaped seat. No, it is not safe to mix and match (stock wheel with tapered lugs or vice versa); the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure.
Oh okay... Yea I put them on because I'm missing some of the stock ones... Those are faded anyways... I'll be swapping them out soon... I rather have all 4 then like 2 on each...
I guess you and I have different opinions because i'd rather be safe and not worry about my "cool" lug nuts damaging my wheel or them coming loose.
usdm prelude non vtec models are 4x114 10 inch
you can get the rear rotors from fastbrakes.com
http://www.fastbrakes.com/ProductDet...TR+rear+rotors
.... your car is too sexy the way it is
