LED cluster question
Old Feb 14, 2010 | 07:09 PM
WeB's Avatar
WeB
Default LED cluster question
So I went to Superbrightleds.com to get red leds for my 96 ex cluster. Problem is I went to their sylvannia link and it said I needed 194 bulbs, but it turns out I only needed one of those bulbs to fit the larger socket ( in between the bottom of the tach and the speedo) so now I'm stuck with a bunch of big bulbs I can't do anything with. Can anyone give me the exact bulb number and quantity for a 96 civic cluster and climate control as well? I searched honda-tech but couldn't find a definite answer. Any and all help appreciated. Thanks
Old Feb 14, 2010 | 07:14 PM
Neiser's Avatar
Default Re: LED cluster question
I would love to know exact number also!
Old Feb 17, 2010 | 05:27 PM
WeB's Avatar
WeB
bump
Old Feb 21, 2010 | 05:55 PM
2000gsr-dragon's Avatar
are you talking about the tiny ones ? i did my 2000 cluster in led bulbs. i dont know if there the same bulbs but ill look and post the part number tommorow when i get to work. my audio guy got me a hook up on mine .
pic is all leds in all slots.
fyi ....because they use so little power they do not do well in the low fuel light. that light uses variable volts so the second that bulb see's any volts it will illuminate....
Old Feb 22, 2010 | 10:38 AM
ok so i stopped by the shop i got my bulbs from and saw only t5 on the package. im not to sure if this will help ya or not but im posting these for you too see, i had to use a dremel tool to carve out some plastic in each black bulb saddle in order for the led bulb bodys to fit down in side of them. the grey saddles fit right in no problem.
Old Feb 22, 2010 | 11:26 AM
WeB's Avatar
WeB
ok cool thanks. I only planned on doing the illumination bulbs, not the cel, battery, fuel light, etc. so I don't think I'll run into that problem.
Old Feb 23, 2010 | 06:13 AM
you can do all the bulbs, just not the fuel one! its the only lowvoltage bulb in a cluster.
Old Feb 23, 2010 | 06:14 AM
im sorry low voltage senceing ! to be correct .
Old Feb 23, 2010 | 08:28 AM
WeB's Avatar
WeB
Yeah, I'm pretty sure the T1.5 twist lock bulbs from superbrightleds.com will work, but I'm still stumped on the tiny *** ones for climate control. I might just put a led strip light and splice it into the existing wires if I can't find the right bulbs.
Old Feb 28, 2010 | 06:51 AM
send me a pic of them as i gotta tear down my dash and do them next. ill find them -
Old Feb 28, 2010 | 02:57 PM
WeB's Avatar
WeB
eh, car didnt come with the bulbs in the climate unit sorry, i can tear out the dash ones. have a spare cluster lying around somewhere, i'll get on that today or tommorow
Old Feb 28, 2010 | 04:18 PM
Hill4589's Avatar
Lots of good info in here
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/ref-gauge-lighting-questions-answered-1862248/
Old Mar 3, 2010 | 04:03 PM
voz's Avatar
voz
Good Link
Old Mar 3, 2010 | 05:49 PM
Dark_Ferio's Avatar
That looks great! I wonder who I could get to do that for me!
Old Mar 4, 2010 | 05:01 PM
not a badd job to diy, just pull cluster and bulbs the tiny bulbs are harder to find but the reg backdrop bulbs will light the whole gage face (3) on the teggs
maybe 30min job.
cmross13
Dec 7, 2011 08:44 PM
ej6hatchie
Mar 5, 2008 09:44 AM
ef93si
Jan 29, 2006 06:29 PM
BoostinEJ1
Jan 14, 2006 04:07 PM
d15b7racer
Sep 5, 2003 08:37 AM
