having power door lock problems in 2004 Accord - help!
i have a 2004 accord and its having power lock problems.... first one power lock stopped responding on passenger door (a few weeks after a collision repair in that door), only works manually. Then eventually all the door locks stopped working from the remote, but if you press the the power door lock button on the door panel, it still works 3 of the 4 locks.
This originally started after a collision repair was performed on the passenger side door...
It sounds to me like two different problems to me but do you guys think it could be some sort of power lock "unit" ? Multiplex control unit? door lock motor on passenger side? What else could be causing my problems?
I will take the door panels off to inspect for loose wires but still, all advice is appreciated.
Thanks in advance.
PS does anybody have the FSM for this vehicle
Thanks in advance.
I would take the door panel off and inspect for any visable damage. The door lock accuators are pretty common problem and their is a strong likely hood it could have mutlipul door lock accuators failed but with out a hds to see what the multiplex is commanding
Issue's with unlocking my door with the key.. it seems to jam when inserting the key it takes about four trys i replace the key when my remote went out and would not unlock doors
A Tribe Called Honda
Feb 27, 2007 01:31 PM
