Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Electrical issues with immobilizer and lights. Help!!
Old Nov 7, 2023 | 09:05 AM
Ozzo's Avatar
Default :Solved: Electrical issues with immobilizer and lights. Help!!
New user here! Sorry if i made mistakes with rules or something. Admins remove if so.
​​​​2005 Honda Accord Eu model decided to start doing some weird stuff. Car was standing in the parking lot and suddenly it started to flicker its lights rapidly. Does this in uneven sequenses. ( front and rear lights). Green key light flashing on the dash. Some relay clicking rapidly but it does it at the same time as the lights flicker so its probably the relay for lights... When you put the lights switch into "ON" the lights stop flickering. Lights flicker even if the key is not in the car and doors are locked. Engine cranks but does not start with either of the keys. Radio does weird stuff also. Took the negative terminal off for an hour and after connecting it again, same thing happens. Immobiliser problem maybe? Cars interior is little moist so that could have something to do with this... Anyone has had same kind of problems? Help!
Old Nov 7, 2023 | 10:05 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Electrical issues with immobilizer and lights. Help!!
Could just be a bad car battery.
Old Nov 7, 2023 | 10:23 AM
Ozzo's Avatar
Forgot to mention in original post. Battery is 4months old and terminals are not corroded so that can be ruled out.
Old Nov 7, 2023 | 10:44 AM
Ryanthegreat1's Avatar
Failed MICU especially if the interior is damp.
Old Nov 13, 2023 | 04:51 AM
Ozzo's Avatar
Solved! I used some moisture absorbers and left them in the car for few days. Car works normaly now. There probably was some moisture in place where it isnt supposed to be and caused this.
beginmyhonda
Aug 4, 2011 08:01 AM
ah789454
Aug 15, 2009 11:17 PM
Perryk
Jan 12, 2007 11:54 AM
philipwk
Oct 14, 2005 06:49 AM
huy1224
Jan 5, 2003 02:15 AM
