Crank pulley removal 03 V6
What kind of puller should be used to pull the pulley off the crankshaft, after the bolt is removed? I have a puller, but I'm not sure if it will work or not. Is the pulley hard to pull off? Will I even need a puller? I am gathering tools and tips for my future timing belt job.
Re: Crank pulley removal 03 V6
99.9% of the time the crank pulley just comes right off no issue at all although the crank bolt is the pita on the v6's 3/4 inch gun or nothing for me don't even attempt the 1/2 inch gun anymore
I have never taken off a pulley, but it can't be that hard with the proper size puller.
Originally Posted by 99blackcivicSi
(Post 45043585)
I have the pulley holding tool, and an impact socket. I don't have an air compressor at home, but we use 3/4" drive breaker bars and tourque wrenches at work, that could probably turn the earth. We use them to bolt and unbolt industrial equipment , using 1 1/4" bolts tourqued to over 600lbft (then hammer wrenched). That 8' long 3/4" breaker-bar should do the trick. If not, by chance, I could drive it the mile to work, and slap that 3/4" two handed impact wrench on it. It will not refuse that kind of power. It will laugh at that silly little bolt, hahaha! |
Well then it sounds like you got it handled :thumbup:
Originally Posted by redline1219
(Post 45045300)
