What the hell is this knocking?
Old Nov 21, 2006 | 05:38 PM
02 accord's Avatar
Default What the hell is this knocking?
Before valve lash adjustment:
http://webpages.eng.wayne.edu/~aw1944/100_2475.MOV
After valve lash adjustment:
http://webpages.eng.wayne.edu/~aw1944/100_2487.MOV
Engine idles smooth after the adjustment, but the knocking is still there. The first vid was taken when the engine was still somewhat cold, but it made that noise when cold and warm. The second vid was taken with the engine warmed up.
It should be obvious that the car is an 02 accord. The engine is an f23a1.
Old Nov 21, 2006 | 06:14 PM
Stealthman80's Avatar
Default Re: What the hell is this knocking? (02 accord)
doesnt really sound any different, you have to let it work the new adjustments in its ususaly louder at first then it quiets down
Old Nov 21, 2006 | 06:22 PM
02 accord's Avatar
Default Re: What the hell is this knocking? (Stealthman80)
It's not a valve knock that I'm talking about. I know that the valves make some noise, but this sounds like a diesel engine running. Right after the adjustment, I noticed that the engine runs much smoother (less knocking/ticking from the valves). Now, at idle, the original knocking is almost silent, but as the engine speed increases a little bit, the knocking becomes audiable. It sounds like it's coming from the lower-inside of the engine.
Old Nov 21, 2006 | 09:19 PM
chomorro's Avatar
Reads like a rod bearing, but its an 02 so i doubt it. But who knows....
Old Jan 18, 2007 | 07:08 AM
lunarone's Avatar
i'm searching for an answer to this too, as my car sounds the same... Extremely shitty sounding. please help if you can
tegman85
Sep 27, 2006 09:51 AM
Elbowpunk
Mar 23, 2006 11:01 PM
sickofitall1113
Jul 7, 2005 07:35 PM
ericlee303
Apr 28, 2003 11:50 AM
Comptech98GSR
Aug 27, 2002 08:55 PM
