vtec help
Old Mar 27, 2012 | 10:55 PM
tinasteele's Avatar
Icon2 vtec help
I have a 1994 honda accord with a f22b1 swap from a 97 vtec. The vtec lock up control solenoid valve isnt hooked up and i cant seem to find info or even a picture to were it goes
Old Mar 27, 2012 | 11:30 PM
GhostAccord's Avatar
Default Re: vtec help
Do you have a VTEC ECU?
If your Accord was non VTEC and you swapped in a VTEC engine. You will need to run a VTEC ECU and add the wire from the solenoid to the ECU.
Old Mar 28, 2012 | 12:26 AM
tinasteele's Avatar
Would that be the reason why it geels like the trans is sliping
Old Mar 28, 2012 | 03:46 AM
dglassmyer's Avatar
You are going to have to do a couple things, the first of which, like ghost said, is figure out what ecu you have.
Depending on whether that ecu is obd1 or 2 will determine where the vtec solenoid is pinned to.
Refer to this link for pinout locations.
http://www.innovatemotorsports.com/r...ecu_pinout.php
As for the trans slipping issue, no, that's going to be something seperate.
Driving an f22b1 without vtec feels normal below 2800 rpms and turns into a total dog when pushed much higher.
Spookythescary
Mar 30, 2018 11:18 PM
vtechaccord
Mar 14, 2011 03:03 PM
DXDOHCVTEC
Jul 29, 2004 10:34 PM
digitalhav0c
Apr 9, 2002 11:05 AM
