Trouble!!!!
Old Sep 16, 2004 | 12:50 PM
hondahottie91's Avatar
Default Trouble!!!!
My 91 Accord has been acting up. Once every few months it just will not start. I then get it towed and then once it gets home it just starts again. This time it has been 4 days it will not start or react to a jump. I think it may be the distributor but I'm not sure. What else could it be? And how hard is it to replace the distributor??
Old Sep 16, 2004 | 12:57 PM
phoenixitc's Avatar
More info might help. What happens when you turn the key in the ignition? Click, click, nothing...?
Old Sep 16, 2004 | 12:59 PM
Default Re: (phoenixitc)
it sounds like it is going to turn over but doesnt have enough ummmfff. Ya know what I mean no clicking. And the started was replaced 2 months ago. I thought thats what it was so i fixed it....but the problem is back again!
Old Sep 16, 2004 | 01:01 PM
FatJoe's Avatar
Default Re: (hondahottie91)
check the plugs? maybe your wires need to be replaced... distributor could be the problem. check for spark.
Old Sep 16, 2004 | 01:03 PM
Default Re: (FatJoe)
I checked for spark last night....nothing. And I just replced the spark plugs about a month ago. How hard do you think changing out the distributor will be?
Old Sep 16, 2004 | 02:08 PM
H2290's Avatar
A distributor is not bad at all. But see if you can't replace just the cap or something first. Maybe it's got a crack or something and is grounding out. I always say replace the cheap stuff first and then if it still doesn't work . . . rig it! Or buy the expensive part, whatever.
Old Sep 16, 2004 | 02:13 PM
motormanSR's Avatar
i agree with H22 check your distributor cap first...and the little rotor inside for ware and then replace if necessary...also when was the last time you changed your feul filter?
Old Sep 16, 2004 | 08:49 PM
hondaacuratech's Avatar
check for distributor seal leaks, look underneath distributor housing. if it is, oil got inside ignition compoments. you need new dist.
Old Sep 19, 2004 | 03:16 PM
3rd accord's Avatar
I've had two honda's where after work they would not start for about 1/2 hour. This usually happened when the weather was hot. I'd get out to the car, open the windows, pop the hood and try to figure out why it wouldn't start. Called the tow truck and when they came it started right up. This problem has only happened on our older hondas. Someone told me that Honda has a part called a starter relay. It is located somewhere under the steering column. On two accords this was the problem. Its a suggestion for something to check.
Old Sep 19, 2004 | 04:12 PM
FatJoe's Avatar
Default Re: (3rd accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rd accord &raquo;</TD></TR><TR><TD CLASS="quote"> I've had two honda's where after work they would not start for about 1/2 hour. This usually happened when the weather was hot. I'd get out to the car, open the windows, pop the hood and try to figure out why it wouldn't start. Called the tow truck and when they came it started right up. This problem has only happened on our older hondas. Someone told me that Honda has a part called a starter relay. It is located somewhere under the steering column. On two accords this was the problem. Its a suggestion for something to check. </TD></TR></TABLE>
4th gen accords are notorious for main relays going bad... so thats def something to check out
Old Sep 19, 2004 | 05:02 PM
luckydog's Avatar
Default Re: Trouble!!!! (hondahottie91)
It COULD be the ditributor, or a part of it anyway. The distribitor on my 91 was trash. And Honda dizzys are not known for their longevity. If it's the original part and not causing your current problem it will act up sometime. I got a good deal on mine at http://www.importperformanceparts.net
Good luck.
Closetgeek
Dec 9, 2015 04:45 PM
intgraCA
Jul 27, 2006 09:12 AM
mycarz
Nov 28, 2005 05:15 AM
hondahottie91
Sep 16, 2004 01:34 PM
GQ Cowboy
Dec 14, 2003 09:55 PM
