starter
Old Jan 8, 2004 | 01:44 PM
smb88's Avatar
Default starter
I own a 1994 Honda Accord. The starter is bad and it needs to come out so I can have it re-built. How hard of a job is this? Do I access if from the top or bottom?
Any help is appreciated...
Old Jan 8, 2004 | 02:10 PM
Lo82284's Avatar
Default Re: starter (smb88)
Honestly if i were you i wouldnt bother re-building that starter. I have a 95 Accord and I replaced the started last year it isnt too hard of a job its just takes alittle time and patience. You need to take the batter out thats the only thing there are 2 bolts on it one is on the top where u can see it and the othere is under the started really an easy job. But dont bother with the rebuilt just get a new one
Old Jan 8, 2004 | 05:43 PM
CB3's Avatar
CB3
Default Re: starter (Lo82284)
yea dont rebuild it. Unless your really bored and have money to blow. You can get a Reman'd one at Honda or even AutoZone for less money than it would take for you to rebuild one
Old Jan 8, 2004 | 06:43 PM
brads94accord's Avatar
Default Re: starter (CB3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CB3 &raquo;</TD></TR><TR><TD CLASS="quote">yea dont rebuild it. Unless your really bored and have money to blow. You can get a Reman'd one at Honda or even AutoZone for less money than it would take for you to rebuild one
yeah, right on, just buy a remanufactured one from autzone, mine was $150 for my 97 accord after i got my core charge back. it took me about 30 minutes total once i found my 14mm socket. you have to remove the battery and use an extension to get to the bottom bolt which is a 17mm and the top bolt you can see is a 14mm. just make sure you have a breaker bar or cheater's bar handy. i didn't have one so i took apart of my little sister's old razo scooter things and used the handle bar as a cheaters bar. those bolts are in there tight.
Old Jan 8, 2004 | 07:49 PM
ForceThis!'s Avatar
junkyard $50
rspi
Sep 20, 2014 06:46 AM
hondaaccordlxig
Jun 28, 2014 06:56 AM
thatasiankidtony
May 3, 2008 09:06 PM
ceyazzie
Jul 1, 2007 08:55 AM
Delano5050
May 18, 2007 09:22 PM
