Stalling
Old Jul 23, 2008 | 04:10 PM
paboy's Avatar
Default Stalling
I have a 93 Honda Accord with 136k that is stalling when backup up on a driveway or driving to a stop sign. Have replaced main relay, Ignition switch, Ignition coil, Ignition module, plug wires, spark plugs, fuel pump, and fuel filter been recently changed. Also when i put it in gear giving it gas with brake it has no problem stalling, not sure if this is going to help anyone solve this problem. What possible problem could it be? I at a lost with nothing else to do, what else could it be?
Old Jul 23, 2008 | 04:42 PM
mavvrik's Avatar
So basiclly all your saying is your car is stalling on you?
Driver error....??? maybe...?
Old Jul 23, 2008 | 05:13 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
have you replaced or checked your distributor cap and rotor?
Old Jul 23, 2008 | 05:23 PM
mavvrik's Avatar
Ohhh. So your car is just dying on you? Ok, I get it now!! Yeah, I would second that distributor cap and rotor.
Old Jul 23, 2008 | 05:42 PM
JDMHenro's Avatar
Default Re: Stalling (paboy)
Honestly dude I was having a similar problem to that just the car would turn on and then stall, then wouldn't turn back on till i waited maybe a couple of minutes....all my mechanic told me to do is fill up my gas tank with gasoline not containing ethanol and pour in a fuel system clean up and a water remover and honestly dude its working pretty good so far and it was cheap! I hope it helps! Tell me what you think
Old Jul 23, 2008 | 07:00 PM
paboy's Avatar
Default Re: (mavvrik)
thanks for your reply.yes the distributor cap and rotor was been change about a year ago
Old Jul 24, 2008 | 05:29 AM
accord99power's Avatar
Default Re: (paboy)
check sensors like the tps and clean the iac sensor and check, sounds like an idling problem, air filter is obviously clean right?
NOTUNINGNONADA
10
Nov 21, 2017 04:11 AM
GuitarPunk015
Jun 25, 2009 03:24 PM
the_militant
Oct 3, 2006 03:05 AM
shhh151
Jul 25, 2005 03:47 PM
