Should I replace lower tube seals?
Old Oct 22, 2014 | 05:23 PM
MIDNIGHTTUNER's Avatar
Default Should I replace lower tube seals?
So for my 1997 Accord, I noticed a considerable amount of oil in the spark plug wells, I ordered a valve cover gasket and tube seal set for the car. Should I change them out and pray that I don't need to change the lower seals under the rocker arms? Or should I wait until I get the lower seals and do it then along with a valve adjustment?
Old Oct 22, 2014 | 09:21 PM
holmesnmanny's Avatar
Im assuming you got a non vtec. It would be best to do it when doing the valve adjustment. Its good maintenance. Just make sure to tighten the locknut to specs as you finish each one. Also make sure there is some drag in the feeler gauge as you do each one.
Old Oct 22, 2014 | 11:16 PM
Default Re: Should I replace lower tube seals?
Yes it is a non-vtec. I just got my gasket in today. I ordered a felpro gasket that came with the tube seals and cover grommets. What are these? Sorry for the size... Totally forgot how to reduce it.
Old Oct 22, 2014 | 11:19 PM
Thanks, I'll see if the shop at my school has the appropriate feeler gauges.
Old Oct 23, 2014 | 06:02 AM
The left is the lower the middle is the upper spark plug tube gaskets .. i really dont know wut the right one is wut part number is that and how many of that right one did you get ?
Old Oct 23, 2014 | 10:36 AM
Yeah the left o ring matches that. The middle one is made of metal with a hard rubber outer bit. Might be cam seal? The right looks like for maybe distributor? I'll poke around more to see what it could be..
Old Oct 23, 2014 | 02:38 PM
So this is what it is: 1)Lower tube seal, 2)Cam seal, 3) Crank Seal. Not bad for less than $10 since I got all that and the upper seals and the cover gasket.
tjlewis10
Jul 8, 2017 09:38 AM
tr7driver
Mar 11, 2008 06:56 AM
EFz6er
Dec 11, 2007 05:29 AM
RaceMyGhost
Jul 7, 2006 11:03 AM
KOALA YUMMIES
Oct 29, 2002 06:44 PM
