Seafoam
Old Dec 1, 2011 | 05:54 AM
  #26
Turbo-LS's Avatar
Default Re: Seafoam
Seafoam is nothing like marvel mystery oil. Seafoam is a solvent, its not ment to improve oil or gasoline its a cleaner plain and simple. Its cleans injectors out and buildup on the valves when used through the gas, when added to oil it breaks down sludge and oily buildup on internal parts, it also thins out the oil which is why it can only be used and let the engine idle then the oil has to be changed right after and not driven on or it will damage the engine from lack of lubrication
Old Dec 1, 2011 | 09:08 AM
  #27
accordmatt's Avatar
Default Re: Seafoam
EXACTLY
Old Dec 1, 2011 | 01:16 PM
  #28
curtie94's Avatar
Default Re: Seafoam
I know the sound is not bottom end because I can't hear it when I put the screw driver on the block. It also goes almost completely away when warm. The only place I can hear the sound is around the #4 cylinder exhaust, The #4 Cylinder on the valve cover and on any valve cover bolt.
Old Dec 1, 2011 | 02:34 PM
  #29
Turbo-LS's Avatar
Default Re: Seafoam
That doesnt mean it cant be bottom end. the wrist pins will get quieter as the engine warms up and everything expands. just keep an ear out and if the noise gets worse you know it could def be bottom end. If you seafoam it, you will clear up any gunk build up and should be able to hear the sound more if its in the bottom end
Old Dec 3, 2011 | 07:42 AM
  #30
curtie94's Avatar
Default Re: Seafoam
Heres a pic of the manifold crack
Old Dec 3, 2011 | 09:15 AM
  #31
Turbo-LS's Avatar
Default Re: Seafoam
That could definatly be your noise. I had an Elantra with a cracked manifold and it sounded like head noise and got quieter after warming up lol
Old Dec 11, 2011 | 06:43 PM
  #32
EJ8_Man's Avatar
Default Re: Seafoam
Actually... I've considered this since I use seafoam before every oil change. Letting it idle is typically not enough. I do like the manufacturer says:
"To clean built-up oil residues and contamination from the crank case, add 1½ oz. Sea Foam® to each quart of engine oil. Sea Foam® will slowly re-liquefy residues and suspend contaminants for easy removal. Monitor oil for color and clarity and change oil and replace filter when oil looks dirty."
So basically - check your oil, note the color, add seafoam, drive the car and let seafoam do its thing, then when the oil changes color or darkens replace it
Old Dec 12, 2011 | 10:05 AM
  #33
bdmlilburn's Avatar
Default Re: Seafoam
removing of some of these contaminants that form around the various oil seals on older engines will leave areas for oil to leak.
Old Dec 12, 2011 | 06:25 PM
  #34
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Seafoam
If crud, grime, grease, varnish or carbon is plugging a leak in a seal, then the seal needs to be replaced anyway.
Old Dec 13, 2011 | 03:44 PM
  #35
EJ8_Man's Avatar
Default Re: Seafoam
Exactly. It's not logical to denote a product as having a negative impact simply because your motor needs repair.
Old Dec 13, 2011 | 04:01 PM
  #36
bdmlilburn's Avatar
Default Re: Seafoam
i was simply providing a warning. im sure many people will read this and dump seafoam in their motor thinking of how clean they are making their engine and trying to make their vtek hit harder. most of these people probably dont realize they could be needing to replace a seal or two and end up with some really unwanted leaks
but i agree mike. a bad seal definitely needs replacing. i guess seafoam can also be a good way to find out if your seals are failing before they really go
Old Dec 13, 2011 | 06:31 PM
  #37
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Seafoam
It's actually a great way to locate that exhaust leak you've been looking for. Just look for the smoke blowing out of a gasket.
Old Dec 13, 2011 | 08:58 PM
  #38
EJ8_Man's Avatar
Default Re: Seafoam
It's also a great way to smoke out your neighborhood. Dump some down your spark plug holes and take it for a drive :D
Old Dec 19, 2011 | 03:18 AM
  #39
Flagmichael's Avatar
Default Re: Seafoam
I've used a shop vac in reverse to find exhaust leaks - tape it to the tailpipe when the engine is cold and listen/feel for leaks. Amazingly the hiss can be heard from about a foot away when the shop vac is running if the vac is as far away as it will reach.
I would sure believe that manifold leak (pictured) is noisy. The thing about exhaust manifold leak noise is that it can't be heard on a mechanic's stethoscope, so if there is still noise coming off the engine itself there is something else going on. I confess I have never dealt with wrist-pin noise, so I defer to those with experience in it. My experience with rod knock and exhaust leaks is that leaks get louder with increased throttle, while rod knocks become slightly harsher but not much louder.
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
pr3lude1992
Apr 1, 2009 05:33 AM
85_305
21
Jan 12, 2009 01:51 PM
Petah
Honda Civic (2001 - 2005)
Apr 26, 2007 03:07 AM
kornerk12
Dec 18, 2005 03:27 PM
