Rev limmiter at 3grand
Old Jan 25, 2018 | 08:59 AM
Zac Richardson's Avatar
Default Rev limmiter at 3grand
Just bought a 5spd 94 accord and i think somethings wrong with the vtec cause it will bounce off rev at 3grand in every gear including neutral makes it really hard to drive up a hill cause once i start getting into the power of the gear it just hits rev😒. Any help will be greatly appretiated
Old Jan 25, 2018 | 01:04 PM
holmesnmanny's Avatar
Default Re: Rev limmiter at 3grand
first check for codes using the paperclip method
Old Jan 26, 2018 | 04:59 AM
Fitz Williams's Avatar
10 Year Member
A little bit simplistic, but you said you just bought it. Check to make sure you have a Hitachi distributor with two plugs and both are plugged in. Someone could have replaced the distributor.
Old Jan 27, 2018 | 11:59 AM
MAD_MIKE's Avatar
MM Gruppe B
Verify there is enough oil in the crankcase.
Low oil = low pressure = no VTEC pressure switch activation = no powa above ~2700rpm.
Verify that your CEL lamp works.
Turn ignition to II(ON) and make sure the CEL comes on during prove out and turns off when the engine starts. If the CEL does not come on then the lamp may be burned out and will need replacement.
Old Jan 27, 2018 | 01:05 PM
could even be a clogged cat
bjones6215
Sep 2, 2013 10:07 PM
Mike Makovsky
Honda Civic (2001 - 2005)
10
Feb 20, 2013 09:07 AM
hfrex
19
Sep 16, 2009 04:42 PM
hondarazor23
Jan 29, 2009 07:53 PM
2k1 GSR
Mar 14, 2005 10:39 AM
