powersteering problem?
Have a 91 accord coupe bone stock and the power steering fluid in the reservoir keeps on leaking out from the top of the cap. I always fill it to the max line then after a week or so the fluid is all over around the reservoir tank. All lines seems fine no leaks but seems like the area around the hose clamp is always soaked.
What can be causing this?
try filling only part of the way between max and min. lines, then slowly turn your steering wheel back and forth to get out the air bubbles.
how much spills out?- is there a lot of grime built up on your pump/hood?
From the sounds of it it may be bubbling up and over flowing.
You probably have a leak somewhere in the line allowing air to get in there that travels to the reservoir and then causes it to bubble.
Look for leaks near the pump and rack.
Checked the steering rack last night and looks like it is leaking from the passenger side. The boot is ripped and I can see fluids around the area but didn't think of turning the wheel to see if it leaks.
Checked the price for a new one and its pretty expensive. Might go the with a rebuild kit, it seems like you just replace all the gaskets in the rack and pinion then you have a new one. Right?
How difficult is to rebuild the steering rack? Should I just buy one from the parts store?
i think it's simpler just to get a rebuilt rack from the store
so the only thing to worry about is an alignment job after you r & r it & add the honda-only specified fluid and bleed out the air bubbles as stated earlier
i got one with a lifetime warranty for other makes/models and they've held up until you hit a pothole and rip that dust boot, inner seal again
Bubble Gum Jr.
Jan 1, 2003 12:38 PM
