No signal to ecu
Old Jan 17, 2008 | 09:41 PM
cB7KiD's Avatar
Default No signal to ecu
car died out in the drive way warming out one morning. CEL popped on so i threw it on are scanner and it says CEL 0 which means no signal to ecu.
i have no spark
any idea how i can fix this? or what the problem is?
thanks josh
Old Jan 18, 2008 | 02:40 AM
GhostAccord's Avatar
Default Re: No signal to ecu (cB7KiD)
Here is a good place to start. Check your No.1 fuse and your engine/ECU ground wires in short.
Here is a more detailed process...
Does your low oil pressure light come on when you turn the ignition on (engine not running)
No - Check your No.1 fuse. It's the 10A fuse for your backup & meter lights.
Yes - ......How knowledgeable are you with the electrical of your car? You are going to have to do some diagnosis on your ECU ground wiring.
• Turn you ignition on (engine not running) and Measure the voltage between body ground and Terminals A23 and A24 individually.
Is there less than 1.0V
Yes - Substitute a known-good ECU and see if that solves the problem
No - Repair the open in BLK wire(s) between ECU and G101 (ground junction located at the intake manifold) that had more than 1.0V
chadek86
12
Jan 20, 2009 09:30 AM
sirhavok
May 30, 2007 06:45 PM
onepoint-gsr
Feb 28, 2006 01:55 AM
Markb16a
Nov 7, 2005 08:23 PM
Spy1r
Mar 3, 2004 08:30 PM
