Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Accord (1990 - 2002) (https://honda-tech.com/forums/honda-accord-1990-2002-2/)
-   -   nitrous users (https://honda-tech.com/forums/honda-accord-1990-2002-2/nitrous-users-1620763/)
honda3x23 May 8, 2006 08:37 AM
f series nitrous users
can you post pics and detailed info of your set up please? i'm most interested in:
-where you tapped into the fuel
-what fittings you used to tap into the fuel
-what line you used to go from the fuel to the solenoid
-what fitting you used to go from the fuel line to the solenoid
thanks. i'm making the conversion just have never done a wet kit b4
jfish May 8, 2006 02:22 PM
Re: f series nitrous users (honda3x23)
All the lines will come in the kit. as far as the fuel feed you have to cut your fuel line where it goes into the rail. nx or zex are good kits
honda3x23 May 8, 2006 11:00 PM
kits are a rip off, i make all my own.
i wanted to tap into the check valve on the fuel rail, just wondering why nobody does that and everyone cuts the fuel line
AFAccord May 9, 2006 10:43 AM
Re: (honda3x23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3x23 &raquo;</TD></TR><TR><TD CLASS="quote">i wanted to tap into the check valve on the fuel rail, just wondering why nobody does that and everyone cuts the fuel line</TD></TR></TABLE>
Probably for good reason. Maybe most nitrous users don't want to risk their motor to a home grown setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3x23 &raquo;</TD></TR><TR><TD CLASS="quote">kits are a rip off, i make all my own.</TD></TR></TABLE>
I highly doubt you could do better R&D than what's offered. If you have to create a post asking these questions, then making your own setup is probably a bad idea in the first place. https://honda-tech.com/forums/images...es/emdgust.gif
notoriousB May 9, 2006 10:45 AM
Re: (honda3x23)
"check valve" on the fuel rail??? are you referring to the fuel pressure regulator?
eagleclawracing May 9, 2006 10:28 PM
Re: (notoriousB)
i cut the line but when i taped it on my fuel rail it seems to work better but i think the hose im using is to big so iddno its rich in the first couple of thosands rpms them leans the hell out at the higher ones i uped my fuel jet 3 sizes over what holly recomnded so i ddno
honda3x23 May 9, 2006 10:34 PM
afaaccord.. for the record you have no idea what your talking about, and your post wasnt worth posting so why dont you keep your non informational posts to yourself.. thanks bye
notoriousb.. no the little nipple for testing fuel pressure right next to where teh fuel line meets the rail.
eagleclawracing.. the hose from the fuel line to the solenoid? maybe a walbro 255 will fix that for about 60-70 bucks???
notoriousB May 10, 2006 07:19 AM
Re: (honda3x23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda3x23 &raquo;</TD></TR><TR><TD CLASS="quote">notoriousb.. no the little nipple for testing fuel pressure right next to where teh fuel line meets the rail.</TD></TR></TABLE>
gotcha. so you want to cut that off and use that as the feed? why not just buy an aftermarket rail which has a fitting on it already?
honda3x23 May 10, 2006 08:00 AM
Re: (notoriousB)
i wouldnt be cutting it off, i'd just be screwing a hard line fitting into the hole instead of othe bolt that goes in there normally and then running a an line from there to the solenoid just like an aftermarket rail i guess
notoriousB May 10, 2006 11:01 AM
Re: (honda3x23)
interesting, I like it. any idea of the flow capabilities of that port? I'd be a little concerned that it might be too small since it's only for a gauge, but then again the no2 doesn't use a huge feed line at all. I wonder what the thread pitch is on that? 1/8" BSPT perhaps?
i_kick_turtles May 10, 2006 03:20 PM
Re: (honda3x23)
I think that is a 4an port. I've never seen this done on an accord before. I don't know how much this will help, but it's a dry to wet conversion on a grand prix, there are a lot of line sizes for solenoids, etc.
http://www.clubgp.com/newforum...79204
honda3x23 May 11, 2006 12:39 AM
notoriousb &gt;&gt; i'm sure the line would be big enough nitrous lines arnt big at all.
but what eagle claw said is bothering me about him not getting enough fuel hopefully its cuz his lines too big and too much fuel is getting sent to teh solenoid adn not to the rail maybe
eagleclawracing May 12, 2006 09:08 PM
Re: (honda3x23)
i think its because of the fuel rail im leanin out because when put it back on the stock fuel hose its spraied better
