Ignition Switch Replacement
Old Dec 21, 2005 | 06:13 AM
urbanlegend21's Avatar
New User
Default Ignition Switch Replacement
My ignition switch has gone bad. Or atleast I am diagnosing it as that.
Has anyone ever done a replacement of the switch? I know it involves drilling out the old bolts because they are break off head type.
If that is the most difficult part then I am in the clear.
Old Dec 21, 2005 | 07:15 AM
drktorn's Avatar
Default Re: Ignition Switch Replacement (urbanlegend21)
before you start, what is wrong with the ignition switch?
you dont have to drill it out. carefully use a hammer and a flathead. put the flathead in an angle and hit it counter clockwise to loosen the screw. if you want to replace it with a 10mm or 12mm if you like.
Civic Racer X 7
Feb 25, 2011 12:31 PM
migizzel
Dec 5, 2005 03:46 PM
davew
Aug 28, 2001 05:57 AM
