help low compression!!!
Old Jun 15, 2009 | 10:15 PM
sirt_eg's Avatar
Default help low compression!!!
Broke a ringland and just replace it with a new piston with new rings. Installed everything and the compression was still giving me 120. compression test is 120/250/245/250. I'm guessing the valve seal? can a valve seal lower your compression? hopefully its not the valve. any help will be great. Also there is smoke coming from the breather. theres no oil leak or anything.
Old Jun 16, 2009 | 08:50 AM
hondamark35's Avatar
Default Re: help low compression!!!
more info.
what's the mileage? was the cylinder rehoned? did you do the repair or did a shop do it?
since you're asking about the valve seal, i'm assuming you didn't check, or have it checked while the head was off. a leak-down test may tell you more than compression in this case.
Old Jun 16, 2009 | 09:24 AM
accord_raffi's Avatar
yes leakdown's will help pinpoint where you're losing compression. valve seal do lower compression to answer your question.
Old Jun 16, 2009 | 11:00 AM
Originally Posted by car5car
Valve seals don't lower compression, they prevent oil leaks thru guide. Check compression with 2 tea spoons of oil added to cylinder
yes... good call.
valve seats on the other hand can lower compression
Old Jun 16, 2009 | 01:25 PM
my mistake. I must have misread about it before. I've always wondered to myself 'how would a bad valve seal lower compression?' A valve seat makes much more sense. Thanks for correcting me.
ef9itb
Feb 6, 2011 06:21 AM
usdmblackcivic
Sep 4, 2010 11:56 PM
CNSK
Apr 10, 2005 08:54 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
Slammed2K1
Dec 5, 2003 07:35 PM
