having problem's checking the check engine light
Old Jan 14, 2009 | 11:52 AM
chad olson's Avatar
Default having problem's checking the check engine light
my 1990 honda accord will not start so iam trying to check the cel i put the paper clip and the light is not flashing at all??????need help please??
Old Jan 14, 2009 | 12:31 PM
GhostAccord's Avatar
Default Re: having problem's checking the check engine light
Does the CEL come on at all?
What are your no start symptoms...does it crank over at all? Is it getting fuel into the cylinders? And is there spark at the plugs?
Old Jan 14, 2009 | 12:35 PM
P_Adams's Avatar
There may be no code to display.
There are many things which aren't ECM related that can keep a car from starting.
Just how do you mean "Not Start"
No Crank?
Crank / no Start?
P
Old Jan 14, 2009 | 01:35 PM
TheMuffinMan's Avatar
He knows where you live!
Solid CEL is usually an ECU issue
Old Jan 14, 2009 | 01:50 PM
A solid CEL with the SCS shorted = No code stored on the ECU for the 94-97 Accords. I'm pretty sure it's the same for the 90-93 ECUs as well.
A solid CEL with the KOEO and no SCS shorted = ECU problem.
Old Jan 14, 2009 | 03:55 PM
chad olson's Avatar
yea the light stays on????the car cranks but won't start???i checked for fuel and its getting fuel and spark???last week it started but it did not rev past 3,000rpm?????i don't no wats goin on????
Old Jan 14, 2009 | 04:03 PM
twkdCD595's Avatar
OP: Sounds like you have as indicated in the previous posts, an ecu problem... have anyone you know with an accord who will let you barrow their ecu?
Old Jan 14, 2009 | 04:38 PM
chad olson's Avatar
is there any other way i can check the ecu??????
Old Jan 14, 2009 | 04:49 PM
chad olson's Avatar
is there any other senor's that will cause the car from not starting beside the ecu????
Old Apr 5, 2009 | 09:34 PM
js593's Avatar
Sorry to resurect. But i searched, and i found.
I am currently having the same issue with my 90 accord (cb7 chassis) 2.2L F22a1.
No SES code.
Engine ran fine when i left the theater, after warming up, it did this.
The transmission when left in D4 (overdrive) wouldnt go past 3000 RPM (or even lower).
No engine light, no sportshift flashing.
Transmission history: I am having issues with it. It tends to slip when you come to a stop, but then catches when you release the brakes (sounds like a seal might be internally leaking)
Transfered most of the Dex3 that was in there, and replaced it with OEM Honda ATF. Issue still comes up.
Going to check all fluid levels tomorrow (cant tonight, too dark.)
Thanks in advance guys.
Old Apr 6, 2009 | 04:56 AM
js593's Avatar
Just checked fluids. Oil is fine, tranny is fine.
Pulled the fuse for the ecu (10 mins). we'll see if it resets. Other then that, does anyone else know what might cause this?
Old Apr 6, 2009 | 10:17 AM
cctgene's Avatar
One simple thing that can happen that will cause your car not to start, with no error code, is a bad rotor. If your rotor is slipping on the distributor shaft you will have spark but your car will not start. You can do a simple check for this by removing the distributor cap and see if you can move the rotor around by hand. Just ran into this last week on a 91 Honda.
For what it's worth!
Old Apr 6, 2009 | 03:12 PM
js593's Avatar
I dont really think this is a cap and rotor issue. Im getting spark perfectly fine.
I reset the ECU today, and it hasnt acted up since. Im guessing just some wierd programming in the ECU. Gonna keep my spare with me just in case.
Btw, if the rotor was slipping inside the cap, it would demolish when it hits one of the studs, or the metal would wear out VERY fast.
The car starts fine also. runs fine in cold mode.
Old Apr 6, 2009 | 03:50 PM
phex206's Avatar
New User
do u have any tip on how to shut off or reset the "SRS" on a 1997 accord se? thanks
Old Apr 7, 2009 | 01:13 PM
cctgene's Avatar
Hope you've resolved your problem. The case I referred to was a 91 Honda that would not start. It had good spark, good compression, good fuel pressure and the injectors were all working but it would not start. Tried squirting carb cleaner into the throttle body with no results. I thought maybe the timing belt might have slipped so i removed the valve cover and the crank shaft pulley and checked the timing marks, with the number one cylinder at the top of the of the compression stroke, they were dead on. Remove the distributor cap and saw that the rotor was not pointing at the number one cylinder spark plug cable wire.
I tried moving the rotor by hand and sure enough it moved, the rotor was slipping on the distributor shaft. Put a new rotor on and put everything back together and the car fired right up.
Good spark doesn't mean anything if it doesn't happen at the right time!
Like I said, for what it's worth.
Jakester9500
Mar 20, 2017 06:54 AM
chad olson
Jan 13, 2009 09:30 AM
