f22b2
I know you can buy Mufflers from Mugen and weld them onto a cheapo eBay catback system and its not loud and doesn't have that 'ricer' sound
Hello there so I got a 97 honda accord 4door with the f22b engine and auto trans. And swapping it in to my 92 honda accord 2door but I want to do it as cheap as It can be with more hp. I don't expect 500hp but I'd like to just make something around 200hp to 250hp and cheap. Have kids and limited income to projects I've never built a honda so it's my first.
F22B2 is an OBDII variant which will not simply swap over to your '92(electrically/tuning/ECM).
If the F22A just needs bottom end work, and the B2 is in good order, replace the short block of the F22A with the B2 block. And modify it as an F22A#.
Otherwise most of your budget will be spent on adapting the B2 to the '92.
These engines are similar but are different enough to be a PITA for a budget swap/build unless you are familiar with the minute differences and can do most/all of the work and tuning yourself.
lol Yes you can? You can find turbo kits on eBay with decent parts (minus the actual turbo, they are crap). An air intake will only reduce power, that's already established. They're basically there to look cool and take up less space, they have almost no performance enhancement capabilities. I personally like my header (HEADER, singular) but I can't exactly say I've felt any noticeable power. As for getting name-brand over eGay stuff, definitely. It may look the same but the quality of the material, welds, and build quality are apparent.
and FYI, you would have gotten a lot more results just looking this stuff up on google or the HT refined search. This question has been asked 1000+ times.
I think he was referring to the "Advanced Search" option.
What are you looking for specifically? 9 times out of 10 if you type exactly what you are looking for into a search engine, it will point you to 100's of threads.
Could you talk more about run it on chrome, sorry I'm a total newb w/a f22b2 97 accord that I just put a timing belt and we on (popped my cherries good) anyways, g-friend didn't include the cam seal when ordered so I have that left to do.
Chrome is a tuning software which works with a chipped OBD1 ecu. It is used to tune modified F and H series engines etc.
If you have no mods, you shouldn't really bother much about tuning the engine at all.
OEMaccord96
Nov 11, 2022 01:01 PM
