ECU code 37
Old May 15, 2003 | 03:51 PM
muniman's Avatar
Default ECU code 37
I am having trouble with my 1999 Accord and I was able to retrieve a number 37 computer code. Can anyone help me with the meaning of this code?
Old May 15, 2003 | 07:11 PM
Chiovnidca's Avatar
Default Re: ECU code 37 (muniman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muniman &raquo;</TD></TR><TR><TD CLASS="quote">I am having trouble with my 1999 Accord and I was able to retrieve a number 37 computer code. Can anyone help me with the meaning of this code? </TD></TR></TABLE>
Is that 3 long flashes followed by 7 short flashes?
Old May 16, 2003 | 11:27 AM
muniman's Avatar
Yes. It is 3 long and 7 short...
Old May 16, 2003 | 12:49 PM
Chiovnidca's Avatar
Default Re: (muniman)
That's not a valid code. Are you sure it's not two seperate codes? 30 and 7?
Old May 16, 2003 | 01:45 PM
niedejb's Avatar
Default Re: (Chiovnidca)
Its probably 3 and 7.
Did you swap the connectors on the map and the tps. They will interchange and they are close to each other.
What are the symptoms? Did you change the throttle body or intake manifold?
Old Feb 5, 2014 | 06:56 AM
stenny's Avatar
i got same code i believe its the map sensor i recently replaced the throttle position sensor if anyone else has anymore ideas let me know
ALLshowNOgoLS
May 4, 2006 02:19 PM
civicx
Oct 4, 2005 03:12 PM
foesicks
Jun 4, 2003 09:47 AM
4gnhatch
Jun 2, 2003 12:35 PM
Flexmyrex
Aug 16, 2002 08:46 PM
