DRL not working..
My night lights work and, my high beams are working also.
Just my daytime running lights are not coming on. I see a light indicator for DRL but, it's never on. I checked fuse #10 under the dash to see if it's the issue but it's fine. Is there another fuse under the hood? and is it possible that it's the DRL relay? if so where is it?
This may be applicable, at least you'll be able to pick out the correct module under your dash.
http://www.nyx.net/~smanley/hondadrlfix/
I found this on a canadian web site for you. I can't verify this as I don't posess a Canadian Owners Manual for this car (sorry)
"Here is how it is
supposed to work.
If the parking brake is set when you start the car, the orange DRL light
will come on. When you release the parking brake, the orange DRL light will
go off and the DRL's themselves will come on.
Try the above. If this is what you see with your car, then you're fine. If
you notice something different from what I wrote above, then something could
be wrong. Something with the parking brake perhaps?"
Hope that helps
P
P
hi im trying to find the drl relay on my car
im driving a 97 honda civic hatchback cx 2d
they all work but when i press the brake they go off and wont turn back on
any idea how to fix it with out someone digging on my wallet
Lewspike69
Oct 21, 2020 08:55 AM
cor4ey
Apr 16, 2010 03:53 AM
jjenks
Feb 23, 2010 08:03 AM
95silverteg
Sep 30, 2008 04:48 AM
