Check engine light is on.
Old Mar 25, 2003 | 12:16 PM
accord ex's Avatar
Default Check engine light is on.
Guys, i installed some obx racing headers, and after they were installed my check engine light went on, and a mecanic said that i needed to replace the o2 sensor, will installing the sensor reduce my horsepower? Thanks
Old Mar 25, 2003 | 12:44 PM
urbanlegend21's Avatar
New User
Default Re: Check engine light is on. (accord ex)
nope, whats wrong with the original sensor?
Old Mar 25, 2003 | 12:57 PM
accord ex's Avatar
Default Re: Check engine light is on. (urbanlegend21)
The mechanic said it had too much carbon or something, and it needs to be replace, and he also said that with the new sensor i will save more gas, so does that mean less horsepower?
Old Mar 25, 2003 | 01:03 PM
niedejb's Avatar
Youd get more horsepower out of a new sensor if I had to guess.
I'd focus on why all of a sudden this is a problem.
Did you check what ecu code it is? Have you reset the ecu to see if it goes away?
Old Mar 25, 2003 | 03:36 PM
mickey513's Avatar
YOU HAVE THE REPLACE IT. Since the 02 sensor was probably damage during your install of the header, I would recommend you replace it. The 02 sensors helps make sure your engine gets the proper air/fuel mixture. A bad 02 sensor can lead to poor gas mileage, decrease hp, and many other problems. Your car will mostly be running rich, which can destory the cat. converter and eventually your motor if left in that condition for a long time.
I have a brand new 02 sensor for sale if you need it.
$65 shipped to you. email me at tnt513@juno.com if interested.
[Modified by mickey513, 12:38 AM 3/26/2003]
Old Mar 25, 2003 | 09:56 PM
RKV's Avatar
RKV
Default Re: Check engine light is on. (mickey513)
mickey513, can u get me a brand new o2 sensor for the catalytic converter? i believe the o2 sensor on the header and cat are different. at least the tips are different colors i believe, so im just guessing. are ur o2 sensors OEM brand?
Old Mar 25, 2003 | 10:08 PM
iam7head's Avatar
Default Re: Check engine light is on. (RKV)
before getting o2 sensor notice that the one on the cat wont work on the one in the header. that is true for 6th gen.
the one attached on the cat is little bit longer.
I'll say fu_k it and get a o2 sim.
or you can get tap your 02 sensor with 50 cents parts in radio shack.
it will make the cel go away.
been that done that
Old Mar 25, 2003 | 10:10 PM
iam7head's Avatar
Default Re: Check engine light is on. (iam7head)
niejbe's site have some detail info about making your own o2sim.
i use it when i use my test pipe
WSBowles
Honda CR-V & Element
Apr 12, 2017 04:11 PM
papi123
Honda Civic (2001 - 2005)
Apr 25, 2014 09:07 PM
WhiteXHysteria
May 1, 2012 01:23 AM
thegod
Aug 9, 2008 07:27 PM
91civichatchCrX
Dec 8, 2005 06:03 PM
