Check engine light
Old Aug 31, 2018 | 07:21 PM
Zachcmay2590's Avatar
Default Check engine light
My 99 accord coupe f23a4 ulev vtech has a check engine light for a few things i fixed and replaced the distributor vtech solenoid plugs and wires and the ecm and had it reprogramed at honda and tested the resistance on all of the wires and the check engine light comes back on with the same code after all of that
Old Sep 1, 2018 | 09:31 AM
hondaslave1342's Avatar
Default Re: Check engine light
What codes? Cant help much unless the DTC codes are posted
Old Sep 1, 2018 | 10:24 AM
P1381 the only thing that i have not replaced that could be the problem is when i had the battery tested there was a slight ripple in the alternator so thats my next step unless you have another idea that might be the problem
Old Sep 1, 2018 | 06:08 PM
https://honda-tech.com/forums/honda-accord-1990-2002-2/2000-accord-4cyl-p1381-2813513/
Sounds like your altenator..
Old Sep 3, 2018 | 02:35 PM
Ok so i replaced the alternator and it was ok for about 30 miles the the check engine light came back on so now im at a stand still on what els it could be
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
kantfadedisazn
Feb 3, 2006 08:10 PM
integra_type-r
Dec 14, 2004 04:04 PM
laurat
Oct 14, 2002 12:54 PM
