97 Accord SE Shift Lock
Old Nov 16, 2004 | 12:54 PM
tom5683's Avatar
Default 97 Accord SE Shift Lock
Lately when I put the car into park I have to shut the car off put the key in the shift lock release and then put the car in netural to start it. The car starts fine in park but it will not move from Park, even after hititng the brake. Sometimes it works like normal, others it sticks like this. Any ideas what to do?
Old Nov 16, 2004 | 07:32 PM
cmrvi1's Avatar
Default Re: 97 Accord SE Shift Lock (tom5683)
The next time that happens, check to see if the brake lights are coming on when you step on the brake. They should be on. If they aren't, there might be a problem with the brake light switch. The PCM needs that brake signal in order to release the shifter out of park.
Old Nov 16, 2004 | 07:43 PM
accrdpusha's Avatar
Something similar happened to me. I took it up to honda and they said that there is a small chip right in front of the shifter that was damaged. It cost abot $350 to fix. Might be the same problem.
dlowdog
Dec 1, 2007 07:56 AM
drunkinmiami
Nov 19, 2005 12:52 PM
dintegra97
Apr 11, 2005 06:28 PM
yellowdcn
Feb 28, 2005 01:06 PM
95civicracer
Sep 18, 2003 02:53 PM
