94-97 accord help HELP
hey im new to the honda scene and i bought a what appers on paper to be a 1994 accord lx 2.2 l4 non vtech 16valve? 2 door non abs 4 lug hubs ive got cd7 in my vin so im assuming that but ive gone through the dash and found sv4 and sv2 things? im not too sure what those mean and its got alot of power and this is my first honda so idk what too go off of f22b2 0440970 p2a5 5017468 what im unsure about is the exhaust manifold it looks off from a 1994 cd7 obd1 https://cimg2.ibsrv.net/gimg/honda-t...a7e7d9ec4.jpeg above exhaust manifold https://cimg4.ibsrv.net/gimg/honda-t...d4a662e9c.jpeg above exhaust manifold https://cimg5.ibsrv.net/gimg/honda-t...a461d6748.jpeg im unsure aboutvthe exhaust manifold https://cimg0.ibsrv.net/gimg/honda-t...916c1a7dd.jpeg https://cimg9.ibsrv.net/gimg/honda-t...789a64d0e.jpeg |
Re: 94-97 accord help HELP
your vin decodes as a 1994 2.2 lx, 2 dr, manual, US built, 200k+ miles. the exhaust looks stock to me. use the vin it seems to be correct.
https://www.vindecoderz.com/EN/check...CD7138RA801013 |
I can’t get in account so here this is manifold without cover |
Originally Posted by Johnny Oxner
(Post 51797522)
hey im new to the honda scene and i bought a what appers on paper to be a 1994 accord lx 2.2 l4 non vtech 16valve? 2 door non abs 4 lug hubs In Canada your model range is LX, EX, EX-R. If your car is an original Canadian market Accord it is the equivalent of a US DX model. It has a few non stock and non factory issued parts. PO has installed after market wheels, a Type R style grille, US EX or CAN EX-R lower bumper trim, Ghetto fabulous conical filter installation, and the suspension seems very anti snow drift lifted. If the interior is as in good condition as the engine bay and body, then the car appears to have been well taken care of, outside of some of the unique taste in mods. |
Yah the clock code appears it’s 93 so I’m assuming 1993 ex accord top end (f22a1?) im trying to figure out computer too use for more hp and run better cause old one is wrong 1988 transmission f22a1 head 1993 2.2 F22b ex block 1996 once again car was bought like this but yes interior is nice but black painted interior and grey /gold outside is being painted in summer too white |
Also going through car cleaning it Also head has POB-7 on it Honda logos have SV4 on them but with the suspension it’s almost as it’s from a 93 accord in the front just from the control arms and struts but going for coilovers because it’s really low and shocks are shot any suggestions not too break bank |
why are you referencing parts on chassis that were exactly the same and interchangeable ? like bro you are wasting your own time its a almost 30 year car im sure things have been replaced/maintained etc and obviously things used might not be the exact 94-97 part number for year but its literally all the same shiet for the most part lol.... like nothing rare etc or anything that makes it any different ... the sv2 sv4 is literally nothing ..... if recommend that you just get oe replacement over the counter parts store struts if looking to go cheap and they handle 1-2 inch drop springs fine
Originally Posted by yohon656
(Post 51816510)
I’m new too Honda’s and don’t know much about 4cyl ingeneral tbh I’ve owned Chevy and dodge my whole life. And first I’m doing this on my phone so things can sometimes autocorrect ok. But you can do a 2200cc head from 90-93 and put it on a 96 block allied motor sports sells the parts for it even and yo have you heard of a Frankenstein build or any race built motors yes you can do that please do research before disrespecting another member thanks |
But found trans code p2a5 5017** BLOCK POA-19 head POB-HA-7 could it be a 2.0is |
im not disrespecting anyone im just saying its not likely and wouldnt be a gain... no the kits you are referring to are to put the later vtec and dohc heads on the f22 single cam block....... its not a Frankenstein build or anything out of the ordinary I ASSURE you ... how about just look at the block stamp just left of the exhaust manifold and read what it says ,,, also post a picture of the engine and block stamp or literally stfu
Literally look through post man the pics are there it says f22b2 I get that it’s probably 1994 dx block but I’m just trying too figure out what ecu too run too give more power that is compatable poj , POa ,p12, Or a jdm f22b2 and the usdm and jdm motors are different cause my my ecu is bad and I know because you can see corrosion |
if the car runs it probably doesnt have a bad ecu... and the stock ecu is the best ecu until you go turbo... until then keep it in your pants unless you are spending actual $$$ on performance upgrades
if your car is the one in the pictures its a bone stock motor with a cone filter spliced onto the stock intake... prob makes less hp just from the hot air intake.... there isnt some magic ecu or tune to pull power out of its ass that isnt there dude .... you dont need to even look at a tune until you are like minimum putting cams in it , all a tune is changing for the most part is AFR and ignition timing there is no magic power release button
and all engine components in picture are all OEM OBD1 FACTORY 94 Accord F22 ...
