1999 Accord rear beam compatibility
I am replacing the rear beam in a 1999 Accord with the 2.3 4 cyl but the replacement part is for a V6. It seems to be the same dimension wise but the rear motor mount bolt holes do not line up. Does anyone know if I can use a rear vacuum assist motor mount for a V6 model and have it match up?
https://cimg9.ibsrv.net/gimg/honda-t...2f72d1d318.jpg Rotted 4 cyl rear beam with motor mount mounting holes https://cimg0.ibsrv.net/gimg/honda-t...3686d31b86.jpg one of the mounting points of the 4 cyl rear beam https://cimg3.ibsrv.net/gimg/honda-t...88d38ace5a.jpg one of the mounting points of the V6 rear beam https://cimg5.ibsrv.net/gimg/honda-t...619ec29cf3.jpg V6 rear beam showing motor mount mounting holes |
Re: 1999 Accord rear beam compatibility
Check the part numbers on V6 and I4 cars via one of the many Honda parts websites.
They look the same, verify the V6 crossmembe has the holes you needed punched and threaded. Just use your I4 mounts. |
