___||SOHC Squad||___ v.2!
https://i280.photobucket.com/albums/...fficallogo.jpg
get your SOHC SQUAD DECALS HERE!! http://graveyardgraphics.com/sohcsquadlogos.htm Hey guys well we lost alot of people on the last sohc squad thread, so i got the go ahead from 4g4door and i am now #1 on sohc squad! So please PM me a pic of your car and stats. This is going to be a fresh list! Which means new numbers. Same rules do apply as well. I will also be looking for mods of this thread, so please let me know if your interested and why you would be good for this thread. Here are the rules: Lets show some love for the single cams out there. D's F's and ZC's welcome! THREAD MODERATOR IS C_R_X_V_T_E_C All Hondas welcome! RULES -Must have either SOHC D, F or ZC series motor, NA or boosted. -Must have some sort of modification to their car, i.e. drop, swap, paint...things like that. -Must be active for at least 1 month in the thread before joining the squad. -If unactive for a lengthy period of time, you will be removed from the front page. -Post pics of your ride with specs. -No hating on someones ride. -Please provide technical conversation, lets keep the randomness to a minimum. -Keep it civil and help each other out! If interested in joining, let it be known by stating, "I want in!" or something along those lines. Followed by pics of your ride with engine shots.if you are interested in joining the squad make a post here then also send me a PM so i know the date that you asked to join, helps me and crxvtec keep everything straight. Thanks guys! #1. matt j http://sphotos.ak.fbcdn.net/hphotos-..._1891406_n.jpg #2. 4g4dcruisin https://honda-tech.com/attachment.ph...1&d=1272477169 #3.Snazzy95eg8 https://honda-tech.com/picture.php?a...ictureid=53620 #4.C_R_X_V_T_E_C https://i155.photobucket.com/albums/...Picture072.jpg #5.CDdubz5 https://i775.photobucket.com/albums/...1001603b-1.jpg #6.EJ6-2nr https://honda-tech.com/picture.php?a...ictureid=53713 #7.marquisdee1018 https://i44.tinypic.com/2w53u5g.jpg #8.nayumi0818 https://i920.photobucket.com/albums/...7/PICT0009.jpg #9.lowerex97 https://honda-tech.com/attachment.ph...1&d=1272338722 #10.mr.bronx75 https://honda-tech.com/picture.php?a...ictureid=35559 #11. sina.P https://i603.photobucket.com/albums/...na_DC2/015.jpg #12. 96EJ6LX https://i39.tinypic.com/ae4mdx.jpg #13.y8-ek https://honda-tech.com/attachment.ph...1&d=1275931606 |
Re: ___||SOHC Squad||___ v.2!
Lets up the par a little bit on this one! :thumbup:
I call number 2! ive been part of this Squad since like day 2. I believe i do have a rightful spot at the top! Oh by the way matt, im taking new pictures tomorrow so ill have one up then. Hopefully people will just stick around for longer.
Originally Posted by prelude182
(Post 41632099)
I had to sell my sedan due to 3 head bolts getting stripped into the block. The block was stipped is what im trying to say, some dude bought it from me tho! He was more than aware of the situation with the car but he drove off...havent heard back since. The next day, i picked up my EG haha. |
i just put up a temp one for now from the last thread. just let me know
Hey matt are you familar with egs mechanically? check out my thread in the 92-2000 forum called fuel/air problem
ok got done reading thru it, the iat code will definately throw off your gas mileage considering that the car is still seeing it as cold and thus dumping in more gas then what the car needs. I would also check the plugs if i remember right the IAT sensor and the TPS sensor plugs look identical.
Also maybe do a compression test and check to make sure all is in order there, you could have a leaky headgasket which will show somewhat on a compression test. Try those and see what happens man and let me know, i saw you were going to replace the thermostat already so thats why i didnt mention that. maybe even check the o2 sensor as well make sure its clean, i know it said something about you using the four wire, but just double check it and make sure its in decent working order |
oh and also you can pull your injectors and rail as one but i wouldnt try firing them figure it takes about 2psi to pull the injectors out by hand and there is 35psi in the rail when you fire it. pull the injectors and inspect the orings and such you should be able to tell when one is bad. and oring kits are pretty cheap as well i think 4 or 5 bucks.
Noted, about the IAT, could i have a code 10 if the IAT isnt reading correctly? The IAT is brand new, the wiring is correct, but since the car never "warms up", could it throw the code?
Also, its a b7/z6 mini me swap, vtec wiring has been done in the engine bay.(92 cx/dx/vx all have vtec wired into the dash harness to ecu already for some reason) Thats the reason for the 4-wire o2, its done correctly since im not throwing a code for that. Lastly, the ecu is stil from the b7, i need to find a p28 on the cheap. |
Oh, do you know a guy named Nick Thomas in Sioux Falls?
doesnt sound familiar but i might, and yes you would really want to find a p28 for it since the sensor could read diff but i dont think it would matter that much, check the voltage at the sensor and see, could be that you got a bad out of the box sensor as well
Originally Posted by matt j
(Post 41632503)
https://honda-tech.com/attachment.ph...1&d=1265997761 |
wow thats some shitty wiring
The previous owner told me that he thought the plug was damaged, so he cut it off...the thing that bugs me is that the colors of the harness side dont match the plug side.
The green and red wires on the harness side ALMOST match up with the plug. plug- red/yellow, green/white harness- red/yellow, green so, im confused haha |
(Post 41632575)
no ps no ac no window washing no cruise no factor air box (short ram AEM) |
sounds like mine, let me run out to the garage and see what my wires are on my sensor
edit: ok mine is green/white red/yellow all thru the harness, mine is a 95 vtec harness |
maybe im looking at the wires wrong but it doesnt even look like they are hooked up to the correct wires in the harness. What i would do is undo that nightmare and redo it, so its done correctly and soder and heatshrink the wires or you will probably fry the sensor or worse
(Post 41632644)
yeha thats what im curious about now lol im gunna go dig out my haynes manual real quick
(Post 41632705)
ALright, red/yellow, green/white goes into the plug....so wtf haha.
hmm...there is no mention of a yellow or a black wire going anywhere near the IAT...i see the solid green that LOOKS like the IAT green/white taps into. |
yeah the only ones that i can see on the above is for the o2 sensor. I dont want to rip into my harness since its a fully tucked harness now lol
Yo guys can I join the squad?
