Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
TURBOSMART Boost Controller is here !, even E-Boost Ver.2
Old Jul 15, 2005 | 08:58 AM
Flamenco-T's Avatar
Default TURBOSMART Boost Controller is here !, even E-Boost Ver.2
NO MORE ALLEN WRENCHES!!!
AND MORE OPTIONS FOR A DIFFERENT VARIATY OF APPLICATIONS THAN THE
COMPETITORS!!!
BOOST TEE
-Set your Boost and forget it
-Boost is fully adjustable from under the bonnet
-Detent System for ease of adjustment
-Gated System to bring boost on faster
-Can be mounted with an optional mounting bracket
-Mounting Bracket - BOOST TEE only
-Anodised billet aluminium
-Supplied with all mounting hardware
<FONT COLOR="red">$ 73.45</FONT>
IN CABIN
Designed to be mounted inside the cabin and allows for boost adjustment on
the run. Ideal for the active enthusiast.
-Control boost from the drivers seat
-Mounting bracket, hose and all fitting hardware supplied
<FONT COLOR="red">$ 131.18</FONT>
SINGLE STAGE
Compact design, will fit in the palm of your hand. This unit provides fast
boost response with one adjustable boost level. Ideal for turbo cars
without factory boost controllers. Switch between standard and high boost.
-High Boost setting is fully adjustable
-Includes Rocket Launcher Switch and fitting hardware
-Mounting bracket and fittings supplied
<FONT COLOR="red">$ 164.18</FONT>
DUAL STAGE
boost response with two adjustable boost levels. Just toggle between high
and low on the fly. Ideal for replacing factory boost controllers.
-Low and high Boost settings are fully adjustable
<FONT COLOR="red">$ 188.92</FONT>
E-BOOST Ver. 2
<FONT COLOR="red">$ 425</FONT>
<FONT COLOR="red">It's a tachometer</FONT>
-e-Boost2 displays RPM with a much greater accuracy than the common
analogue tachometer!
<FONT COLOR="red">It's a boost gauge!</FONT>
-With high accuracy boost and vacuum display, e-Boost2 outperforms most
analogue boost gauges!
<FONT COLOR="red">It's a shift light!</FONT>
-With an optional single or double LED ring, e-Boost2 controls up to 2
warning/shift lights!
<FONT COLOR="red">It's a NOS swtich!</FONT>
-With a fully programmable auxiliary output e-Boost2 gives you control over
water spray, methanol or nitrous injection!
<FONT COLOR="red">It's the mother of all Boost Controllers!</FONT>
-Up to 6 alternate boost mapping functions with specific boost mapping for
FWD, RWD, AWD, Bike and Drag racing applications.
-A specifically developed Correction Feature eliminates boost drop-off at
high RPM
-Boost levels can now be mapped against TIME or RPM
-Special gate pressure function eliminates wastegate creep
-Peak Hold/Max Boost Recall function monitors the boost and RPM
-The display can be configured to KPA, Bar or PSI
<FONT COLOR="blue">Features Accessories</FONT>
-Choice of 40 or 60-psi models
-Choice of bezel/face colour combinations
-Back-lit, easy to access function buttons
-Auto dimming
-Programmable audible warning alarm
-Advanced short circuit protection
-Suitable for panel, gauge pod or pillar mounting
-Easy to read, 7-segment display with bar graph
-Housing and accessories made out of tough, billet aluminium
-Single or double LED ring. Available in bezel-matching colours
-Shift/warning lights complete with a plug-in wiring loom, available in
four colours (Red, Green, Amber, Blue)
-Remote-mount shift light
-Dash mounting kit. Tough and sturdy with tilt and directional adjustment
<FONT COLOR="greeb">HERE'S HOW TO ORDER: </FONT>
Please add $ 6.50 for Ground Shipping and send the funds to;
paypal@fast-turbo.com
Call us directly and place your order, 888 887-2658 TODAY !!
Check and MO, please send them to:
Fast-Turbo.com
1150 Blue Mound Rd West
Suite 810
Haslet, TX 76052
Buy direct from an Authorized Distributor !, Fast-Turbo.com
thanks guys,
Stan/Tommy
Modified by Flamenco-T at 2:19 PM 7/15/2005
Old Jul 15, 2005 | 10:32 AM
project dc2's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (Flamenco-T)
i dont get it .. the single stage .. acts like a dual stage ? so tehres a hi and low boost ? err factory spring rate and a high boost ?
Old Jul 15, 2005 | 11:19 AM
Flamenco-T's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i dont get it .. the single stage .. acts like a dual stage ? so tehres a hi and low boost ? err factory spring rate and a high boost ? </TD></TR></TABLE>
The single stage have an on and off switch, turn it off, and you'll be at wastegate spring. When you turn it on, then you'll be at the set boost level.
Same goes with Dual Stage.
Actually I accidentally post this on the wrong forum. I meant to post it on the Sponsor Marketplace forum
stan
Old Jul 15, 2005 | 01:15 PM
all good . i will be purchasing a single stage -
Old Jul 15, 2005 | 02:08 PM
IHaveTurbos's Avatar
Stan,
Looks good I will probally order a E-Boost from you soon.
Old Jul 15, 2005 | 02:23 PM
johnxboi's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (Speed-Factor)
looks to be VERY usefull!
Old Jul 15, 2005 | 02:48 PM
TurboTegB18c's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (johnxboi)
GOOD DEAL! Just ordered one, thanks stan! to Fast-Turbo, Paul
Old Jul 15, 2005 | 08:49 PM
swapit's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (TurboTegB18c)
i got the e boost 2 about 3 weeks ago and its the truth.increased spool up time.no creeping.holds at high boost
Old Jul 15, 2005 | 09:29 PM
sean's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (swapit)
not bad, i may purchase the single stage very soon also.
Old Jul 15, 2005 | 09:44 PM
m R g S r's Avatar
well any boost controller will....it will hold the wastegAte shut longer.....
Old Jul 15, 2005 | 09:58 PM
[C]ACKYWHEELS.COM's Avatar
B A N N E D
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (m R g S r)
^^^ has anybody ever told u your avatar looks like a mouse with his head getting chopped off by a FMIC and blood all over the place? hahaha sorry nice boost controllers
Old Jul 15, 2005 | 11:15 PM
V-SPEC 1's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (Los Angelino)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Los Angelino &raquo;</TD></TR><TR><TD CLASS="quote">^^^ has anybody ever told u your avatar looks like a mouse with his head getting chopped off by a FMIC and blood all over the place? hahaha sorry nice boost controllers</TD></TR></TABLE>LOL, yeah it looks like it.
Old Jul 16, 2005 | 12:28 AM
BB6-213's Avatar
I got one of these, and it looks awesome. Only if I could get the car running I could post some reviews.
Old Jul 17, 2005 | 11:33 AM
fastrunner's Avatar
Default Re: (BB6-213)
bump so I can find this to order one later.
Old Jul 17, 2005 | 01:57 PM
LagunaSecaEG's Avatar
do these boost controllers spike?
Old Jul 18, 2005 | 07:17 AM
Flamenco-T's Avatar
Default Re: TURBOSMART Boost Controller is here !, even E-Boost Ver.2 (LagunaSecaEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG &raquo;</TD></TR><TR><TD CLASS="quote">do these boost controllers spike? </TD></TR></TABLE>
Boost controller do not spike, spiking are caused by small area of WG exit or inadequate WG.
stan
Old Jul 21, 2005 | 09:05 AM
tommyten's Avatar
Stan will not be able to answer any IMs from today until monday due to the NOPI race in St. Louis...please feel free to ask me any questions...I will also be attending the race but will try to find time to get online.
Old Jul 21, 2005 | 12:38 PM
tommyten's Avatar
you can still call in and all orders will still be shipped by the way...
atl328ci
Jul 21, 2005 09:14 AM
MooreBoost
Jan 30, 2005 06:10 PM
