yet another gm 3bar map sensor (serched)
well i serched and found 300 +++ treads now i remember in one ocation i found a direct link to a web site that sells pigtails for the map sensor.
i guess what im looking to get from all of you its some help so i can get the pigtail
my car has been sittin for long time now and i'm so frickin ready please help me out
inlinepro.com sells them you can also make one pepboys sells the connector and pins and everything you need its pretty damn easy
From hondata.com
a GM AC Pressure switch plug was used (Conduct Tite part number 85146 from Pep Boys, about $10). We cut a small slot down the side of the connector to make it fit the MAP sensor.
Hondata now supplies the correct connectors with the MAP sensors.
If you can get to a salvage yard you are almost guaranteed to find the plug there. A lot of GM's usually at the salvage yards, and you can cut off a decent amount of wire with it.
(found one for a friend there for $1.00)
