Would this be a good/bad bottom end for forced induction?
Old Apr 4, 2004 | 03:00 PM
SSS2000's Avatar
Default Would this be a good/bad bottom end for forced induction?
b18b
type r water and oil pump,
eagle stroker kit with rods
je 11:1 pistons.
I know this compression is high for a turbo application, but I could lower compression with a thicker head gasket.
The guy selling it was using a type r head, I will be using my B18B head, will this affect the compression ratio?
Thanks
Old Apr 4, 2004 | 03:12 PM
91sihatch's Avatar
Default Re: Would this be a good/bad bottom end for forced induction? (MilanoRedLST)
the compression is gonna be a little lower with the LS head. I wouldn't bother running a turbo setup on it with that high compression and i am not a fan of the stroker kits. just my 2 cents
Old Apr 4, 2004 | 03:51 PM
SSS2000's Avatar
Default Re: Would this be a good/bad bottom end for forced induction? (91sihatch)
Thanks for the reply...any reason you don't like stroker kits?
Old Apr 4, 2004 | 04:03 PM
ExVtec's Avatar
It would be a tad lower with an Ls head and thicker head gasket, but not by alot. I wouldn't recommend going turbo with that high a compression....you will need a good stand alone and tuner if you want that to be safe and reliable. Which usually doesn't go in the same sentence with turbo anyway...lol.
Good luck.
Old Apr 4, 2004 | 05:08 PM
DENCIO's Avatar
Default Re: Would this be a good/bad bottom end for forced induction? (ExVtec)
sorry to steal your thread!! I bought a set of cp pistons made for gsr 9.4:1 and I am going to use them for my b18a with the b18b head..will this lower my comp or bump it up? thnxx..
Old Apr 4, 2004 | 08:42 PM
SSS2000's Avatar
Default Re: Would this be a good/bad bottom end for forced induction? (hookonboost)
Thanks for the bump
dirtyharryhatch
Aug 27, 2009 02:03 PM
SOHCD16y8
Oct 4, 2005 06:03 PM
2point3h22lude
17
Jun 9, 2005 03:47 PM
mplays
Sep 5, 2002 09:24 PM
type autox
Sep 20, 2001 04:44 PM
