WILL THIS WORK?
I have a 1999 civic EX, with the stock D16Y8 Engine. I also have a TD40H-15G Turbo kit that everyone I’ve talked to say works great on the d16 engines. My problem is that I want the boot but I still want to keep most of my car stock. What, can I do to get the boot without doing major engine work?
But, right now I have the TD40 Turbo Kit its sit at about 7 psi, with intercooler, 300 cc injectors, fuel rail, 6 psi wastegate, and a BOV. Another question I have is will my car run like this? Or should I start looking for a new engine? Hope, u guys can help. Thanks! https://honda-tech.com/forums/images...es/emsmile.gif |
that should work fine on a stock motor... boost away and have fun
the only problem i see is the injector size |
Re: (Topdawgg)
what are you doing for fuel management? Otherwise, you'll be fine with that boost level, hell i boosted a y7/y8 with over a 100k miles on it to 15 psi, no issues at all. As have many others on here.
Re: WILL THIS WORK? (blacknite)
really!! thanks! https://honda-tech.com/forums/images...es/emsmile.gif
What size fuel injectors would you guys Recommend? And much more boots can I put on this setup? Thank! Again https://honda-tech.com/forums/images...es/emsmile.gif |
Oh, almost forgot, what would u guys recommend for a FMU? And should i one if I plan on adding more boots?
Thank!https://honda-tech.com/forums/images...es/emsmile.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">what are you doing for fuel management? Otherwise, you'll be fine with that boost level, hell i boosted a y7/y8 with over a 100k miles on it to 15 psi, no issues at all. As have many others on here. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacknite »</TD></TR><TR><TD CLASS="quote">Oh, almost forgot, what would u guys recommend for a FMU? And should i one if I plan on adding more boots?
Thank!https://honda-tech.com/forums/images...es/emsmile.gif </TD></TR></TABLE> Woa Buddy hold on. Don't go getting excited jsut yet! DO NOT! REPEAT DO NOT BOOST OVER 7PSI with a FMU and limited experience! yo udon't want t o kill that 99 EX engine just yet. sure it will take 15psi if tuned properly but in your situation consider 7psi your safety limit. Dont even consider a FMU, their are cheaper solutions that work better. I have some 450cc injectors FS if you need them PM me. Brain |
Re: WILL THIS WORK? (Brain3208)
Thank, for the heads up Brain3208.https://honda-tech.com/forums/images...s/emsmileo.gif
So, no more boots.https://honda-tech.com/forums/images/smilies/emsad.gif That's cool, i guess. But, how much to you want for those fuel injectors Brain3208? |
$35 shipped
| All times are GMT -8. The time now is 05:48 AM. |
