Will a stock b16a spool a Precision SC63?
Hell yes it will.
2psi by 3500rpm
7psi by 5200rpm
Setup:
Stock b16
Full-Race Mani
Precision SC63
3" downpipe *open*
Tial 46mm 7lb spring
PWR 30x8x3 intercooler
2.5" intercooler piping
TurboXS RFL Bov
Vortech 12:1 FMU
Walbro in-tank pump
That's it.
Right now the other b16 is at the machine shop getting re-worked.
The new head is getting the full treatment.
But we were very suprised how well the b16 spooled this turbo.
Thanks to MotorMatrix and Honda-tech for all the help.
2psi by 3500rpm
7psi by 5200rpm
Setup:
Stock b16
Full-Race Mani
Precision SC63
3" downpipe *open*
TurboXS RFL Bov
Vortech 12:1 FMU
Walbro in-tank pump
That's it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">Hell yes it will.
2psi by 3500rpm
7psi by 5200rpm
Setup:
Stock b16
Full-Race Mani
Precision SC63
3" downpipe *open*
TurboXS RFL Bov
Vortech 12:1 FMU
Walbro in-tank pump
That's it.
And a bored 84mm B16A will spool a T4 .68 A/R P trim wheeled SC63(same wheel diff company) compressor wheeled turbo too!
Just once at 10psi felt GOOD!
2psi by 3500rpm
7psi by 5200rpm
Setup:
Stock b16
Full-Race Mani
Precision SC63
3" downpipe *open*
TurboXS RFL Bov
Vortech 12:1 FMU
Walbro in-tank pump
That's it.
</TD></TR></TABLE>And a bored 84mm B16A will spool a T4 .68 A/R P trim wheeled SC63(same wheel diff company) compressor wheeled turbo too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">
Just once at 10psi felt GOOD!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeper007 »</TD></TR><TR><TD CLASS="quote">is that b16a stock compression?</TD></TR></TABLE>
Yes.
Yes.
thats at stock c/r tho, you cant run too much boost on that.. drop the compression so u can run more boost and you will increase turbo lag. Just curious, why you are only running 7psi on that turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtOwnzMe »</TD></TR><TR><TD CLASS="quote">Just curious, why you are only running 7psi on that turbo?</TD></TR></TABLE>
Simple:
1) hes on a FMU
2) it looks like he still on stock intectors.
7psi is the highest i would go, maybe 8.
Simple:
1) hes on a FMU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk »</TD></TR><TR><TD CLASS="quote">
Simple:
1) hes on a FMU
7psi is the highest i would go, maybe 8.</TD></TR></TABLE>
We're going to put in some race gas and run 13psi for fun on this stock motor.
Who cares anyways, b16's are dime a dozen.
If it blows, 5 hours later we'll have another stock b16 in for some more fun.
Simple:
1) hes on a FMU
haha yuppp
crank up that boost
haha yuppp
crank up that boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Stu »</TD></TR><TR><TD CLASS="quote">why wouldn't he be able to run much boost with a 9:1 cr? that makes no sense.
stock b16 compression is like 10.2:1 (around...)
</TD></TR></TABLE>stock b16 compression is like 10.2:1 (around...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArtOwnzMe »</TD></TR><TR><TD CLASS="quote">thats at stock c/r tho, you cant run too much boost on that.. drop the compression so u can run more boost and you will increase turbo lag. Just curious, why you are only running 7psi on that turbo?</TD></TR></TABLE>
Really? 11psi @ stock B16 for me.
badass!!!!
Thats basically the turbo I have and I have similar results!!
the b16 can support some nasty turbos thats for sure!
make a video!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid »</TD></TR><TR><TD CLASS="quote">
badass!!!!
make a video!
I wouldnt call "7 psi at 5500rpm" a "supporting turbo"
badass!!!!
make a video!
LOL. Just make sure u get all on video.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk »</TD></TR><TR><TD CLASS="quote">How high can u boost a b16 on stock injectors but with a upgrade fuel pump(lets say a 255)</TD></TR></TABLE>
officially jacked thread
im gonna go the sc61 route, sc63 is probably good for your stock compression at 7psi. i also would like to see some videos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude »</TD></TR><TR><TD CLASS="quote">i wish i was wealthy and bored enough to try that</TD></TR></TABLE>
If you don't try it you won't know the true results.
NO video's anytime soon I'm 4 hours away from my car. I'll be gone for about two months.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOLMTR »</TD></TR><TR><TD CLASS="quote">
Modified by RyanAutry at 3:56 PM 8/11/2003
